rebuilding a 208? ever do it?
Discussion in 'The Garage' started by sled_dog, Sep 3, 2003.
  1. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    I think my 208 needs a rebuild job. You can wiggle the slip yoke in the rear and the shaft in the front so I think both the outer bearings are done. Has anyone around here ever done it themselves? Rebuild kits are like $150 on ebay.
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I am currently in the middle of this with my 208 for a 700R4. It is pretty simple tear apart. It is all pretty straight forward. As you get in there you will see.
    I haven't gotten around to the reassembly yet so I am not sure how tough the reassembly will be. I just hope it works right when I get everything back together.
    You can get a parts diagram at your local GM dealership along with most the the bearings and such. Napa also carries alot of the bearings. If you can't find the bearings there then Drivetrain.com has just about everything.
    Harley
  3. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    any special pullers or anything needed?
  4. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    Nope, the only thing I ran into is some of the large c-clips on the gears are a PITA to get off. And there is also a fairly large nut for the front output that you need a large socket for (over 1").
    Also when you pull the mainshaft be over a flat large surface. About 80 needle bearings will fall all over the place. I learned the hard way. Over a large oil drip pan would work great. Beyond those things I used standard hand tools to remove everything.
  5. 87sm465np208
    87sm465np208 1/2 ton status
    Aug 28, 2002
    1,114
    illinois
    the wiggle you feel in your rear shaft is the worn out bushing that is in the tail houseing, that is a cheap part to replace by timkin at autozone, about 8$ for a new rear seal and the bushing. /forums/images/graemlins/thumb.gif
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/truck.gif
  6. rustyk5
    rustyk5 Registered Member
    Aug 3, 2003
    63
    Hampden, ME
    Just started this week.
    Bought a video that walks you through whole process including inspection. $30 from technical video, they're on the web. Rebuild kit **complete** national drivetrain $125 + shipping. Have'nt torn into the case yet. right now it's draining into an oil pan(and my driveway!! /forums/images/graemlins/tongue.gif)
  7. steelsoldiers
    steelsoldiers 1/2 ton status
    Oct 17, 2002
    365
    Charleston, West Virginia
    I rebuilt mine twice. Once it kept popping out of gear because of worn out shift forks. The second time was because I shattered the front case half /forums/images/graemlins/eek.gif /forums/images/graemlins/shocked.gif. I used the National Drivetrain kit the first time. It was very complete. I used my trusty Haynes manual to redo it. A slide-hammer bearing puller would have been handy, other than that, just a good selection of hand tools will work. Good luck. /forums/images/graemlins/thumb.gif
  8. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    I just did mine using a Haynes manual, it has pretty good instructions. Im planning to do a write up, I took lots of pics, but I also installed a SYE
  9. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    I was thinking about SYE too, whats the budget on that one without new shaft?
  10. outlaw612
    Feb 11, 2001
    2,342
    I payed about $200 if I remember correctly. That was for the Dodge parts from K10andyknamic. Then I just had to buy the yokes($25 each) and the rebuild kit (about $125).
  11. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    I just finished the reassembly of the NP 208 last night. It isn't to difficult as long as you have a decent memory and the diagram. I got it back together without alot of hassle. I resealed it and it will be going back in tomorrow. I tested the shifting last night and I have all ranges. 2hi, 4hi, Neutral, and 4low so it is all good.
    Harley
  12. BigBurban350
    BigBurban350 1/2 ton status
    Jun 9, 2002
    711
    Michigan
    Is a 241 about the same as a 208? Mine wont stay in 4 hi and I got the engine out and I might as well remedy that problem.
