rebuilding a 241
Discussion in 'The Garage' started by TorkDSR, Oct 3, 2004.
  1. TorkDSR
    TorkDSR 1/2 ton status
    Sep 1, 2001
    1,258
    bucks co pa
    what am i rebuilding and why.
    the case has been apart by a previous owner whom i cannot contact.
    all the bearings are good, any way to check chain slop without the thing assembled?
    how would i see chain wear?
    and how much beefier is the HD chain, this one looks kinda stout, like 5 links wide or so.
    THanks guys
  2. TorkDSR
    Sep 1, 2001
    1,258
    bucks co pa
    ok, its 10 links wide
    TTT
  3. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i usually check the chain by pulling the drin plug or fill plug and pushing on the chain.
  4. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    If the chain gets bad you will know it pretty quick. They don't usually just break. You will hear it hitting the case if it is streched out pretty bad.
  5. TorkDSR
    Sep 1, 2001
    1,258
    bucks co pa
    thanks for all this support guys
  6. TorkDSR
    Sep 1, 2001
    1,258
    bucks co pa
    ok, bttt, what kind of deflection do you look for in the chain.
  7. btolenti
    btolenti 1/2 ton status
    Sep 28, 2003
    644
    Gilroy, CA
    I would like to know this too. Is there some "play" in the chain? I just bought a 241 from ebay and in 4HI you can hold the transfer case input shaft and rotate the front or rear outputs about 1/32 of a turn or so....
  8. TorkDSR
    Sep 1, 2001
    1,258
    bucks co pa
    bttt
    what is the width of the hd chain?
  9. btolenti
    Sep 28, 2003
    644
    Gilroy, CA
    regular chain is 1.25" wide
    HD chain is 1.5" wide. /forums/images/graemlins/thumb.gif
  10. TorkDSR
    Sep 1, 2001
    1,258
    bucks co pa
    thank you.
    is there a site with good info on it, or is that just common knowledge /forums/images/graemlins/thinking.gif
  11. btolenti
    Sep 28, 2003
    644
    Gilroy, CA
  12. TorkDSR
    Sep 1, 2001
    1,258
    bucks co pa
    thanks man
