Rebuilding a old 350
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Kajun_K5, Aug 8, 2001.
  1. Kajun_K5
    Kajun_K5 Registered Member
    Jul 9, 2001
    48
    Lafayette, Louisiana
    I just got a '79 K5 with a 350 V8. The motor is shot and I'm going to pull it and start rebuilding it next weekend. Is any modifications ya'll would recommend while I have it out that would be fairly inexpensive. I already figured I would go ahead and board it out and change the pistons but anything else?
    Why the hell not?
    http://www.geocities.com/daniel_ray_deville/My_Blazer/my_blazer.htm
  2. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    High perf parts everywhere, although that may get expensive... Use a high volume/pressure oil pump, too, to keep the blood flowing well (instead of re-using the stock pump)!
    Do you know how the motor is shot? Thrown bearings? overheated to death?
    Ratch
    <P ID="edit"><FONT class="small">Edited by newyorkin on 08/08/01 10:41 AM.</FONT></P>
  3. Mreetz
    Mreetz 1/2 ton status
    Jun 26, 2001
    1,282
    Subs of Denver, Colorado
    Stick with low torqure and low compression. Don't go overboard with too much cam. Edelbrock and Rochester seem to be the best carbs for 4 wheeling, they don't choke when unlevel. I've heard that headers really aren't worth the gain in horsepower because of the buildup of heat from them. I guess if you had the hot coated you could avoid that. 2 1/2" exhaust dual, if you are allowed to in your state. Oh yea, get you a new ignition designed with multi spark and rev limiter if its in this budget.
    1984 K-5
    4" lift
    35x12.5 MTs
    buildin a 400 for it, any info greatly appreciated
  4. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Before you rebuild it check on how much it is going to cost to get done what you want. Then look into the crate engine option. It might be cheaper for you to go with a crate engine. I have seen 350 4 bolt main longblocks at Autozone for about $800 with a warrenty.
    <font color=blue>Wayne<font color=blue>
    <font color=blue>Happy Trails<font color=blue>
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Rebuild carb, Edelbrock Performer intake, Comp Xtreme 4x4 cam, either the 250/258 grind or the 254/262 grind, Vortec heads and proper intake to go with them if you can afford them, and definitely a set of Jet-Hot coated headers and dual exhaust. Lose your EGR, smog pump, and cat if you can get away with it. It'll clean up your engine compartment a lot.
    If it spun a bearing or something, be sure to check it if needs to be line bored or honed. Have it magnafluxed to check for cracks. Don't bore it too much, either. I'm sure you knew all those things, but I figured I'd mention it anyway just to be sure.
    I don't know if the high volume/high pressure pump is necessary. I have the M55HV high volume pump in mine and I get 70 PSI at 3000 RPM. That's a lot of oil pressure. If I had it to do all over again, I'd have the standard volume/pressure pump with the Z28 spring in it that costs about 60 cents from the GM parts counter.
    Tim
  6. xnoahx
    xnoahx 1/2 ton status
    Oct 12, 2000
    817
    Ventura, CA 93004
    I really dont think that jet hot is neccesary, for the cost that is, maybe if you get the dynomax headers that are already coated for about $210. Annd also, there is so much room in a blazers engine compartment that it gets a lot of cool air. Other that the possability of heat, no reason not to run headers. Everyone that races motor vehicles agrees that if you want to improve power you should improve exhaust flow.
    Check out my 73 K5 <a target="_blank" href=http://members.theglobe.com/xnoahx/73k5.htm>http://members.theglobe.com/xnoahx/73k5.htm</a>
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Yep, those are the ones that I have, the coated Dynomax ones, $206.
    Tim
  8. Mreetz
    Jun 26, 2001
    1,282
    Racers get air flow over their engine because their speed, our heat problem comes from going slow and without the benefit of air flow to cool us down. Also a good reason to install an electric fan. just my .02 worth
    1984 K-5
    4" lift
    35x12.5 MTs
  9. Kajun_K5
    Jul 9, 2001
    48
  10. Kajun_K5
    Jul 9, 2001
    48
  11. shupach
    shupach 1/2 ton status
    Dec 28, 2000
    648
    Dallas, TX
    can anyone say Weiand 6-71 Blower?
    phill
  12. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    if you do go with hivolume oil pump make sure you have the big oil pan. i seen the big mistake of having a smaller(pass car) oil pan in specially at high RPMs.
    here is a source for rebuild, www.naparts.com they carry the 383 kit w/crank for about 550.
    go with the vortec heads and stay in the low end power range.
    ARQ.
    1-72 4x4 CST Blazer
    2-71 4x4 CST Blazer
  13. Neil
    Neil 1/2 ton status
    Jun 10, 2001
    275
    Dothan,Alabama
    AutoZone remanufactred motors. I know people who've made that mistake. Crate or rebuild is the way to go. Vortec heads/intake for carb or TBI are great for K5s. 160 degree thermostat and elec. fans are good investment too.
    Neil H.. Alabama.. '78 K5 400ci 4x4 AT,AC,PW Cheyenne. '74 C10 3spd/floor 250ci 4x2
  14. newyorkin
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    I was thinking about this project on the way home from work today. When I get off my butt and pick up a 350 to rebuild, I'm probably going to look for 87 or newer for the heads (since the Vortec equipment costs an arm and a leg), then a full TPI system. If I pick up an older one, I'll try to find the 87 up heads and a full TPI, but would be fine with TBI.
    I don't know what your preference of fuel delivery is, but I figured it might be something to think about. I think if you go crate you have to put on your own fuel system anyway, but I could be wrong.
    And just my opinion, strictly my opinion, I don't think re-using an oil pump from a blown motor would be a smart way to protect your investment in this motor. If you need to spend only $6 instead of $30 (even a new stock pump with the high press spring, at least you will know it's not worn out or hiding metal particles and waiting to spit them into your new motor), maybe it would be a better idea to wait until more funds become available to do it all right the first time. Again, this is strictly opinion.
    Ratch
    <a target="_blank" href=http://k5.8m.com>k5.8m.com</a>
    **Your ad here**
