Rebuilding a power steering pump??
Discussion in 'The Garage' started by surg82k5, May 23, 2002.
  1. surg82k5
    surg82k5 1/2 ton status
    Feb 7, 2001
    416
    San Antonio,Texas
    I have a 2wd power steering pump on my dads truck, it leaks a whole bunch of fluid usually when parked over night.. I am just wondering how difficult it is to rebuild one and where should i get a kit with all the seals.. and anything particular I should look out for... thanks for the help..
    Sergio
  2. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    Never rebuilt a PS pump before, but have had several PS leaks, mostly from hoses (you didn't say if you checked those or not, but I would start there as it is easier). I have also had 2 leak at the high pressure outlet where the high pressure line connects and goes to the steering box. A little (emphasize little) tephlon tape after removing the hose and fitting from the back of the pump and cleaning them, and the leaks disappeared. Just things to consider first (or you may have already, if so, ignore this). HTH
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    It's not that hard to do, but you need to have the right tool to remove and then reinstall the pulley. Once that's out of the way, the rest is pretty easy. But compare the prices between the seal kit and a rebuilt pump. Sometimes the difference isn't worth the hassle.
  4. four_by_ken
    four_by_ken 1/2 ton status
    Jun 9, 2001
    3,806
    Allenton, MI
    Just making sure here.
    Pwer steering pump, or the power steering box?
    Ken H.
  5. surg82k5
    Feb 7, 2001
    416
    San Antonio,Texas
    Well Ken .. I am actually talking about the box not the pump... sorry didn't really think about what i was typing.. sorry for the confusion and thanks for helping me clear up my mistake...
    Sergio
  6. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    If it's the steering box, then all bets are off. Go buy a rebuilt one. /forums/images/icons/cool.gif Oh yeah, unless you're doing a crossover steering swap, a 2WD box won't work on a 4WD anyway.
  7. four_by_ken
    Jun 9, 2001
    3,806
    Allenton, MI
    Because like others said the pump, just buy another one.
    I myself am going to rebuild a box real soon. /forums/images/icons/smile.gif
    I caught myself saying pump a few times when I was talking about the box really.
    Ken H.
  8. Ryan B.
    Jul 18, 2001
    5,693
    CA
    That is so common just to say "go buy another one"
    In my night class we have been rebuilding P/S pumps, gear boxes (both manual and power assisted) and rack and pinions. Everyone is scared to rebuild these things, but when the teacher walks you through all the parts and how to rebuild 'em it's cake.
    All are pretty easy. If your gearbox is leaking i'm going to guess its leaking out of the top seal like mine.
    You can go to Napa or maybe Kragens and get the new seal for the top of the steering box, undo the steering linkage at the rag joint, and installing the new seal should be easy with it still in the truck.
