Rebuilding a steering column.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by rugger03, Jun 29, 2002.
  1. rugger03
    rugger03 1/2 ton status
    May 14, 2000
    829
    around
    I purchased a tilt steering column which needs to be rebuilt, has anyone done this or know af a place that does it. The threaded shaft that locks the steering wheel on has been striped smooth. And the output from the column to the steering shaft is so deformed they will not fit together. I have a donor non tilt and can get another tilt column for parts if needed. Any info will be appreciated. thanks, rugger
  2. 95 Silverado
    95 Silverado 1/2 ton status
    Nov 9, 2001
    467
    Central PA
    with what would be involved in changing that stripped shaft I would think it would be easier to repair the other column or buy one that doesn't need fixed. If you can find one with a loose tilt swivel it can be repaired much easier than changing out those other parts, there are some webpages I've seen that show whats necessary to repair the loose swivel. If you're interested in a good column, I have one out of a '90 blazer, tilt, automatic shift, cruise and delay wiper controls, with a deluxe wheel. good luck with whatever you decide.
  3. rugger03
    May 14, 2000
    829
    around
    Thnaks for the info, I sort of figured that after looking at the diagrams. I'm sending you a PM.
    rugger
  4. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    There are places that do rebuild columns. As to who they are or how to find 'em, that's a little tricky. They can't base thier business on building columns, the one shop I know that did this was also just a regular body shop. Anyhow, I'd do some web searches and you should be able to round up a few shops that do this type of work. There's also a couple of shops on ebay that continuously sell rebuild columns, don't know if they are any good or not, but I'm sure you could get thier shop name, call 'em and see what they have to say.
    BlazerMan
