rebuilding a TBI - instruction set?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by solowookie, Apr 8, 2002.
  1. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    OK does anybody have rebuilt instructions for rebuilding a TBI? I just got my rebuild kit, but there isn't any kind of instruction set, and I'm wondering what the various torque specs are?
    is there a way I can clean the injectors, or just spray them down as best I can with TBI cleaner (picked up up from NAPA).
  2. Charly
    Charly Registered Member
    Mar 29, 2002
    28
    Portland, Maine
    I have the torque specs at home...won't be able to ge them for you until tomorrow, if that's Ok.
    I am in the middle of rebuilding my TB unit as well.
    Make sure to check the play in the throttle valve shaft.....there are no bushings stock, and it's know to wear and create vacuum leaks. They make bushing kits to fix any extra play/wear.
  3. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    thanks I will have to check that; the TBI is together & bolted up to my engine, but the engine isn't in yet so I could pull it & put it back on pretty easy.
  4. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    I rebuilt mine about a year ago. If I remember correctly there were no torque specs in the instructions.
  5. TwoCrowsDesign
    TwoCrowsDesign 1/2 ton status
    Jul 13, 2001
    387
    Jeff, I think I got em all, let me know if you need other figures.
    Note: Some are in inch pounds.
    John
    Mod 220 TBI Torque Specs:
    Fuel meter body screws - 35 in/lb (4 Nm)
    Inlet nut - 30 ft/lb (40 Nm)
    Outlet nut - 21 ft/lb (29 Nm)
    Fuel meter cover screws - 8 in/lb (3 Nm)
    TPS attaching screws - 18 in/lb (2 Nm)
    IACV, Thread Mount- 13 ft/lb (18 Nm)
    IACV, Flange Mount, screws - 28 in/lb (3.2 Nm)
