rebuilding a tranny
Discussion in 'The Garage' started by 69K5, Dec 5, 2002.
  1. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    title says it. how hard is to rebuild a tranny? its a th350. it wont leave second even with fluid. i was thinking about trying it myself. /forums/images/graemlins/confused.gif its how i did my first motor at 14. i took it apart and 3 months later it cranked. /forums/images/graemlins/grin.gif lotta books and wasted effort. now i can do it in 2-3 days if the machine shop isnt slow. i am driving my car for now so time is not an issue. afetr this i want to learn to swap gears. im just an average shadetree mechanic, but i probably have 90 % of the tools i guess i'll need.
    i probably will do the 205 also if i do this
    any opinions.
    69K5
    nathan
  2. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    I think you may need a few special tools for the 350..I know with the 700r4, you need a special tool to compress the cluch packs in the drub whil you install the snaprings...but I am unsure...there is a company called Technical Video, IIRC, that makes step-by-step videos to rebuilding trannies, t-case, diffs, etc...I bout the 700r4 vid from them when I was planning on doing it myself....but I swapped to a manual instead...
    Yes, it can be done and the 350 is a bunch easier than a 700...but I am unsure what tools you need...
    Chris
  3. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    i saw some videos in the library i thought about. is there a way to add an overdrive to a th350? i dont want a 700 r4 and cant find a th400.
    i plan on running 4.10's
    thanks
    nathan
  4. hardcore71
    hardcore71 Registered Member
    Nov 21, 2002
    86
    Weare NH
    As far as automatics go the th350 is probably the easist in the world to rebuild. basic tools, good (GOOD) snap ring pliers and something to compress piston springs (an extra set of strong hands will do) is all you need. For info and maybe even instuctions check transonline.com
  5. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    What do you actually replace when you rebuild a tranny(I would be doing a 700R4) and really how hard is it and how much would it cost to do it yourself?
  6. fortcollinsram
    Nov 8, 2001
    2,261
    Fort Collins, CO
    A typical tranny rebuild just replaces the seals/gaskets, as well as the clutches and steels and bands...rebuilding a 700 is a middle of the road job, but it is also one of the easiest to screw up...I was going to do it but whimped out...that is why I have a 4-speed manual now /forums/images/graemlins/thumb.gifno more burnt ATF or POS autos for me...
  7. 77fixer
    77fixer 1/2 ton status
    Nov 22, 2001
    464
    Meridian, ID 83646
    The only special tool I needed was the low/reverse spring compressor. You'll need that to get it out of the case. Other than that, some good snap-ring pliers and two 6" C-clamps.
    Brett /forums/images/graemlins/burb.gif
