Rebuilding Block
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by grindkings, Dec 27, 2004.
  1. grindkings
    grindkings 1/2 ton status
    Dec 24, 2004
    127
    Marshall, Missouri
    Hey, new here, but I'm planning on rebuild a 350. Its got a one piece rearmain seal. But my question is, does it matter what year it is? Are all the build kits just determined my the rear main?
  2. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Ya that is how I understand it. But to be sure ge the casting number off the block and look it up for the year/years it was used and buy for thoes years for all your parts:D
    Good Luck and Welcome:xmas:
  3. grindkings
    Dec 24, 2004
    127
    Marshall, Missouri
    Thanks buddy, where can i find the casting numbers and where is a good resourse to look them up?
  4. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    go to www.mortec.com, they have the best casting numbers.
    the casting numbers are on the back near where the bellhousing bolts up on the driver side
  5. dyeager535
    26,979
    One piece rear main, check to see if its setup for a roller cam. MOST come pretty much ready to bolt that stuff in, and it's a cheap way to go if you want to make a bit more power.
    Just something to consider if you haven't got cam stuff yet.
  6. K1Orion
    K1Orion 1/2 ton status
    Jan 8, 2003
    812
    st.louis,MO
    Are you just gonna put in new gaskets?
    Or do you plan to put in bearings, rings, pistons, rods, oil pump, and gaskets?
    If its gonna be more than just new gaskets I would suggest getting the minimum of machine work done first. Just ask the machine shop what you got and what you need. They will be able to steer you in the right direction. You will end up with a better motor. Ask me how I know.
  7. grindkings
    Dec 24, 2004
    127
    Marshall, Missouri
    How do you know?
