Rebuilding Carb Uh-Oh
Discussion in 'The Garage' started by mtnman210, May 6, 2007.
  1. mtnman210
    mtnman210 1/2 ton status
    May 30, 2003
    3,880
    Northridge, Ca
    I was making my first attempt at rebuilding one of the quadrajets. I was actually going along fine but then I went to take out the idle rods/screws? and one snapped off. This carb is off a boat that's been sitting for years and everything was a little corroded. Should I be able to get a new screw from the autoparts?
  2. Dudge
    Dudge 1/2 ton status
    Sep 9, 2006
    351
    Kentucky
    Yeah you should be able to find one at a hardware store, or go buy a cheap Q-jet from the junkyard and use it for parts.
  3. 76zimmer
    76zimmer Flyin Rat Premium Member GMOTM Winner
    Nov 14, 2005
    23,029
    1,347
    Kzoo, Mi
    Are these the idle mixture screws? I would think you could get them at a junk yard anywhere, the made gazillions of em. Just check the needle end to make sure its not bent or has a groove in it where it has been forced into the seat.
    Did you get the old ones out?
  4. 76zimmer
    Nov 14, 2005
    23,029
    1,347
    Kzoo, Mi
    If its for the metering rods, I think it should be a common machine screw with a countersunk seat.
