Rebuilding driveshaft question about u-joints
Discussion in 'The Garage' started by sandawgk5, Oct 29, 2006.
  1. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    As you all know I busted my driveshaft and killed the u joint last weekend. Well readymix had some drivelines that he was not using so I have one to fix my broken on and another for a spare. I want to replace all of the joints on these shafts they are stock front shafts with CVs. Question are all of the Ujoints in a stock front shaft 1310 and can I replace them with the forged spicer life series. Would you recommend greaseable or non-greasable for a driveline. I know I run non greasable in the front axle but that does not turn all of the time. I want the forged joint cause my last one broke and took the shaft. I run a welded front so it prolly wont do any good but I cannot afford a HAD shaft right now just to change DL lengths later.
    Ira
  2. sandawgk5
    Oct 28, 2003
    6,881
    TTT for the morning crowd.
    Ira
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    The one at the axle side should be a 1310 ujoint but I believe the 2 in the CV are a different part number/size. I believe they are all available in the Spicer Life Series though. I personally use non-greaseable unless you do lots of mud or water.
    Harley
  4. sandawgk5
    Oct 28, 2003
    6,881
    The only mud or water I see is if it is on the road other than that I run rock and desert.:D Does anyone know the ujoint size for a front stock CV?
    Ira
  5. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    It is not a 1310. I will try to find the reciept I have for the set and let you know.
  6. readymix
    May 30, 2004
    6,706
    26
    S44 (3r)
  7. sandawgk5
    Oct 28, 2003
    6,881
    So it is the same as the rear driveline?
    That is kewl I guess, Spicer makes a Life Series in that size and there is really not much of a cost difference between them and a regular joint.
    So I need 4 S44 and 2 1310 to rebuild 2 front drivelines correct?
    Ira
  8. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    sounds right to me. before you go installing them, i would do some measuring just to be 100%
    that and be sure you get the appropriate lock setup (inner, outer, whatever)
  9. sandawgk5
    Oct 28, 2003
    6,881
    I found the non greasable part number and when I type it in to Napa online it gives me the greaseable joint only. I think I will have problems with the greasefitting hitting **** in the CV. Where do you buy Spicer life series joints that are non greaseable?
    Ira
  10. MattK
    Jan 12, 2005
    1,713
    Dallas, TX
    the grease fittings give me zero issues in my cv...they clear everything and i can get my pneumatic grease gun on them while they are installed. for a truck that sees offroad use(even dirt/rocks) i would prefer greasables.
