rebuilding np 241
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Rustbucket, Sep 16, 2002.
  1. Rustbucket
    Rustbucket Registered Member
    Jul 14, 2001
    55
    northeast tennessee
    I'm having major transfer case problems and was wondering if any of you had rebuilt one of these. It's out of a 91 blazer. Was wondering if this is an easy case to rebuild or should i take it to someone. Also does anyone know of any good websites (other than this one) where I might find some info? Thanks in advance.
  2. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    I remember seeing the rebuild of an NP241 done in (I'm pretty sure) Petersen's 4wheel and off-road. I have kept every issue for the last 5 years, but they are all at home right now (I'm at college). Otherwise, I'd be happy to look for exactly which issue it was. I am also pretty sure it was within the last 6 months or so. Anybody else want to back me up on this one? Check a library near you - first of all to see if they carry Petersen's and secondly to check their backissues.
    The rebuild was fairly simple if I remember correctly.
  3. jc71355
    jc71355 1/2 ton status
    Jan 13, 2002
    830
    Port Neches, Texas
    Yea I think it was the one with the yellow 69 or 70 K5 on the cover. It was a little before summer if I remember right, also had some info about blazer's going topless and security ideas.
  4. chvyhs
    chvyhs 1/2 ton status
    Feb 12, 2001
    1,469
    Murrieta, California
    It looked really simple in the Mag. They said all the parts only went in one way and that is was almost impossible to screw it up.
  5. jc71355
    Jan 13, 2002
    830
    Port Neches, Texas
    Doesn't it allways though? /forums/images/icons/grin.gif
  6. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    I did mine, twice..1st time was for the fixed yoke conversion. &lt;simple.....
    And the second time was cause I F'ed up the unit wheelin. Still a simple job. There are no needle bearings to worry about. Standard transmission sells the chain for about $75 and the rebuild kit which included new bearings, seals, gasket or 2 and the fork shoes (all for about $75. )
    It took me longer to remove it adn clean it up than it did to rebuild it. If you decided to do it, make sure you look at the input gear assembly teeth. This is where mine was damaged. This part was about $80 to replace if I remember correctly. I am by the way about to tear my down again and install a 32 spline input gear, so I may be will ing to sell my input gear to you should you need it. Let me know if you need any help. /forums/images/icons/wink.gif
  7. Rustbucket
    Jul 14, 2001
    55
    northeast tennessee
    Hey thanks for the input. I'm going to get it in the garage tomorrow and take the back cover off and check it out. It's popping out of 4lo, but only when going forward. Reverse is good, but it sucks to back through the woods.
