Rebuilding TB on 1990 K5 (TBI)
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Hardcore, Feb 11, 2004.
  1. Hardcore
    Hardcore 1/2 ton status
    Apr 25, 2003
    458
    New Orleans, LA
    Spring is here and its time to do some work on the K5. My stock 350 runs good but idles a little rough and the rpms fluctuate (surging) at idle. I'm getting a TBI rebuild kit from Oreily for $30 and some cleaner. I'm told it's easy to do, any tips???
    What else should I do? Can I clean the IAC motor, what about the MAP sensor?
    Thanks for the help /forums/images/graemlins/waytogo.gif
    /forums/images/graemlins/k5.gif
  2. detailer03
    detailer03 1/2 ton status
    Sep 23, 2003
    108
    Arizona
    Replace the injectors also.
  3. Hardcore
    Apr 25, 2003
    458
    New Orleans, LA
    What for, they spray fine??? /forums/images/graemlins/dunno.gif
    Besides, too much money considering I'm going to go to a TurboCity setup once I rebuild the engine, no need wasting money on small injectors
  4. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    Just pull it apart clean it and seal it back up...You can add a adjustable FPR like the one from JET or get a GM factory vacuum ref. FPR. I have the JET one on my 454 and it IS better than having NO adjustability but I am itching to get the vacuum referenced one on. That way I will be running stoich at idle and the fuel pressure will jump up as engine vacuum drops as you tip in the throttle...
    There is NO need to replace injectors unless they are spraying like crap or not spraying at all...Also make sure the kit comes with fuel line o-rings and DON'T over tighten the fuel line fittings when you put them back on or you will bust the fuel line boss off the back of the injector pod...
    /forums/images/graemlins/deal.gif /forums/images/graemlins/doah.gif
    Chris
  5. chvyhs
    chvyhs 1/2 ton status
    Feb 12, 2001
    1,469
    Murrieta, California
    Pm'ed you.
