rebuilt 205
Discussion in 'The Garage' started by blank, May 12, 2006.
  1. blank
    blank Registered Member
    Apr 15, 2005
    64
    Texas
    So how much is a completely rebuilt 205 worth?
  2. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    a rebuild kit is around $150 on ebay... if someone knows how to do it themselves, it ain't worth much more than that. If you don't, and you want a professionally done one... I would think $500-700... most of that being labor.
    j
  3. littlejimmythatcould
    littlejimmythatcould 1/2 ton status
    Feb 6, 2006
    797
    Clovis, NM
    Is it that difficult to rebuild one? I know there's a tech ariticle floating around on here on how to take one apart and put it back together. I've been wondering about rebuilding one myself.
  4. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    They're very easy to take apart and put back together, and jek has all the pictures you need. :deal: Just find some tech info if you need a little reassurance.
  5. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    yeppers... send me an email address where you can receive more than 10MB of pics and I'll forward you all the info you need. Full rebuild kits (hard and soft parts) can be found on ebay for $139.99 + $12.00 s/h... just do a search for "205 rebuild" and you'll find them.
    j
  6. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    Depend on the case...a 32 spline input will fetch more than a 10 or 27 typicaly.
  7. MrArmyAnt
    MrArmyAnt 1/2 ton status
    Dec 29, 2004
    662
    Texas, Kick a$$! (Grapevine, DFW; also Norman, OK)
    How do you tell the number of splines? Also I am taking a 205 out of a 3/4 ton sub that was caked over with mud for about 10 years and was driven at a train station. we drained all the fluids in it. should I just clean up the outside of the case or while it's taken apart and drained should I rebuild it?
  8. 79k20350
    Nov 22, 2004
    7,757
    Ct
    when you take the case of there is either a male or female shaft the sticks out the the case, count the slines on it. Or if you know what your looking at youll know what splines because or what transmisson it is
    205 splines:
    400 tranny w/ figure 8 adapter - 32 splines short input
    400 tranny w/ round adapter - 32 splines long input
    350 tranny - 27 splines
    SM465 w/ figure 8 adapter - 10 spline male
    SM465 w/ round adapter - 32 splines long
  9. littlejimmythatcould
    Feb 6, 2006
    797
    Clovis, NM
    If you would, shoot me that e mail my address is strengthofthedragon2@yahoo.com . Thanks. I'm looking to rebuild it for a doubler (hopefully this summer). Do you recken I should rebuild the gear case from my 203 also? I appreciate it.:bow:
  10. 79k20350
    Nov 22, 2004
    7,757
    Ct
    Your there and its all apart... i would
  11. littlejimmythatcould
    Feb 6, 2006
    797
    Clovis, NM
    I found a kit on e bay for the 203 for about $190 without the chain, which is fine because I wouldn't need it anymore anyway. I'm sitting here typing this reply with the LoMax banner flashing in my face...:rolleyes: That would be cool. Doubler with 6:1 ratio...
  12. 79k20350
    Nov 22, 2004
    7,757
    Ct
    not only that, 1:, 2:1, 3:1 and 6:1 so its 4 speeds rather than 3. gotta love that:D you send them your range box, they send it back all ready to go.
  13. littlejimmythatcould
    Feb 6, 2006
    797
    Clovis, NM
    I wonder if a triple stick shifter would be enough for all those gears. That would get kind of confusing until you got the hang of it. I wonder if ORD's triple stick shifter will work for a ATOR doubler. The ATOR doubler is made of steel and the ORD one is made of aluminum. There's always the possibility of stripping out holes with aluminum. The shifter question is probably one best left to the vendor forums. I'll have to ask them before I order all of my stuff.
  14. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    Your 205 tech is on the way. If you go over to the tech article forum, there is a thread there about 205 tech, and it has another 1 or 2 articles not included in the bunch I sent you. I have them, I just don't waste the time emailing them (yahoo is slow with attachments!) because they are easily right-click-saved from that thread.
    As far as the tripple shifter is concerned, I would recommend NWF. Thats what I'm going to use with my WMS (now ATOR) doubler...
    j
  15. 79k20350
    Nov 22, 2004
    7,757
    Ct
    everything still work in the same manner. the differance is that the 203 has a 3:1 and 1:1 instead of 2:1 and 2:1
  16. pvfjr
    Feb 10, 2004
    2,425
    Oakridge, OR
    I think anyone that can customize a hood like that can probably build their own shifters with the right design inspiration. ;) BTW, I'll be making some soon and taking lots of pics...
  17. MrArmyAnt
    Dec 29, 2004
    662
    Is there any way to get front high, front low, rear high, rear low, 4 high, 4 low, without twin sticks? I hear that with twin sticks its easy to accidentally put the front in a different gear than the rear which = bang.
  18. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    no, you have to have twin sticks... one for each shift rail. If the shift rails are modified properly, you shouldn't have a problem with shifting into the wrong gears front/rear...
    j
  19. MrArmyAnt
    Dec 29, 2004
    662
    Ok I see some on ebay for 150... Does anyone fabricate them cheaper? Wait that doesn't include modified shift rails either. If I gove the rails to a machine shop what do I tell them to do? Also on a side note what do I tell them to do to the 8lug military bead locks? I need to change the back spacing.
  20. 79k20350
    Nov 22, 2004
    7,757
    Ct
    theres a few companys on here that customize beadlocks...
    As for the shift rails you can send them to ord and they can do it for you.
