Rebuilt Holley 600 cfm carb...How would this do good off road
Discussion in 'The Garage' started by 84CUCV, Jan 22, 2007.
  1. 84CUCV
    84CUCV 3/4 ton status Premium Member
    Jul 1, 2002
    7,115
    NJ for now
    Its a Rebuilt Holley 600 cfm carb w/ electric choke. I can get it for 175. i need one for my 83. So will this be desent? thanks for the help
  2. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,992
    130
    It all depends what kind of "offroad" you mean but...
    If your truck sees any kind of steep angles you will not be happy.
    IMO, the best carb you can run is a Q-jet. Second place might be a Holley truck avenger or a Motorcraft 2 barrel (I can't think of the number right now :doah:).
  3. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    OK what do Q-jets go for and where can i get one? might try the pick and pull. What did they come on? thanks
  4. 1977k5
    May 26, 2003
    9,992
    130
    Q-jets came on basically every V8 GM made from the late 60's until the mid 80's, and they actually kept putting them on a few cars until 90 or 91. The older ones are better, basically find one from a 70's car or truck and you should be set. If you can find one with an electric choke that isn't computer controlled and doesn't have APT (adjustable part throttle) you will be set. Otherwise you are stuck using a hot air or manual choke. There are lots of threads about Q-jets on here, a search would probably turn up lots of information.
    Edelbrock used to make new Q-jets, you might still be able to find one of those.
  5. rcamacho
    rcamacho 1/2 ton status
    Jul 1, 2004
    1,324
    WA
    I've had good results on off camber and hills by just adding whistle type vent baffles and spring loaded needles to my Holley 3310-1. The 600's have side hung fuel bowls so your results may vary.
  6. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    one last question, can a Q-jet be tuned or handle a motor with heads intake and headers. I not sure if this matters or not just want to check. thanks
  7. 1977k5
    May 26, 2003
    9,992
    130
    Definitely.
  8. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    COOL thanks for the help
