Rebuilt my steering box, now it wont turn right as well as before
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by xnoahx, Mar 1, 2003.
  1. xnoahx
    xnoahx 1/2 ton status
    Oct 12, 2000
    817
    Ventura, CA 93004
    Ok, I removed my steering box from the truck and took it all apart to replace a seal and now that I have it back on, it wont make right turns as well ar it used to. Are there any adjustments that I can make of the steering box to take care of this or will i have to mess with my draglink? I did a search and now im thinking about replacing my draglink ends but I dont see how that would be the problem, I didnt touch those and the steering problems started when I took apart the box. My frame is also cracked where it mounts, need to get the weld in brace.
  2. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    It won't turn right as well, or it won't turn right as far?
    When you put it back on, did you make sure to center it?
    -- Mike
  3. xnoahx
    Oct 12, 2000
    817
    Ventura, CA 93004
    it wont turn as far right as it used to. It looked centered as well as i can tell, I dont think that my steering shaft and pitman arm would have bolted back on if the shafts werent where they were when I removed it.
  4. 88jimmyoungowner
    88jimmyoungowner 1/2 ton status
    Nov 20, 2001
    425
    georgia-rome
    if it turns left farther than it used to, its not centered.
