Rebuilt TBI still not right
Discussion in 'The Garage' started by wayne, Jul 30, 2002.
  1. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Ok, the o2 sensor has been replaced, the tbi rebuilt, new plugs, cap, and roter. Still running like crap. Any ideas? I looked at the spray pattern on the tbi after the rebuild and I still think the one injector is screwed.
  2. tRustyK5
    Jul 23, 2000
    36,173
    1,384
    E-town baby!
    I'd either replace that injector or get it professionally cleaned. The spray pattern should be a fine conical mist, anything different from that means the injector is dirty or malfunctioning.
    Rene
  3. Calclips
    Calclips 1/2 ton status
    Apr 4, 2001
    1,005
    Swartz Creek, Michigan/Flint while in school
    is it throwing any codes?
  4. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color="blue">Compresion test? It's not always electrical related you know...
  5. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
    Definately check codes.
    Also make sure, then double check there are no vacuum leaks. /forums/images/icons/smile.gif
    I found my vacuum line screw in piece... the piece behind the TBI was leaking... gave me a lean condition... I used my regulator to compensate... Lost a bit of power and lost some MPG.
    Good luck.
  6. jc71355
    jc71355 1/2 ton status
    Jan 13, 2002
    830
    Port Neches, Texas
    The one that goes in the Manifold?
  7. TopOff
    Jan 16, 2002
    1,760
    Folsom, ca
    Yep. Sorry for the bad explanation.
  8. wayne
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Thanks for the ideas guys. I will be working on it again tomorrow. Looks like I will try a bunch of things.
