Recalibrating my speedo
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by xnoahx, Aug 30, 2001.
  1. xnoahx
    xnoahx 1/2 ton status
    Oct 12, 2000
    817
    Ventura, CA 93004
    Im sick and tired of my speedo and odometer not reading true. what do i need to do to fix it? The only thing that has changed is the tire size. i now have 36" from whatever the stock size was.
    Check out my 73 K5 <a target="_blank" href=http://members.theglobe.com/xnoahx/73k5.htm>http://members.theglobe.com/xnoahx/73k5.htm</a>
  2. Michael
    Michael 1/2 ton status
    1,576
    Sherman, Texas
    You can get a new drive grear that goes on the tranny(from GM) or have a speedo shop make you a converter...$65 for one in the Dallas area.
    Michael[​IMG]
    <a target="_blank" href=http://www.jmartin.net/parker/goose.htm>www.jmartin.net/parker/goose.htm</a>
  3. dyeager535
    26,979
    GM made adapters too, go look on TH350's and NP205's in teh wrecking yards, you may find some. Maybe they will work for you, maybe not.
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>http://www.dorianyeager.com/index2.html</a>
    No anti-theft measures on your truck? No pity when its stolen
  4. CV202
    CV202 1/2 ton status
    Nov 14, 2000
    454
    Kingfield, ME
    Any ideas on a 1990. the speedo is fed by a sensor in the t-case. I think Superlift made some sort of adapter, but anybody else??
    Why do people keep calling it a Bronco!!!!! [​IMG]
  5. Michael
    1,576
    Sherman, Texas
    You might try these guys....they seem to do it all....
  6. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    Don't know if the '90s are this way or not, but the electronic speedo sender in the t-case on my Dodge is gear driven, you can swap gears just like an older truck.
    Pete
    '83 K5, 350 TBI (ex 6.2), 700R4, NP208, Dana 60/14 bolt, 4.56s, Detroits, 3" lift, 15-39.5x15 TSLs
    '97 Dodge 2500 4x4 CC LB Sport, Cummins 5 spd
