Receiver Shackles
Discussion in 'The Garage' started by daleearnhardt01, Oct 21, 2003.
  1. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    Need yalls recommendations on what kind of receiver shackle I can use with a Keeper Recovery Strap. I have a 2" receiver. Im not to familiar with these things but Im assuming you take the pin out so you can put the shackle through the strap right? I was thinking of something like this
  2. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    I gots me one of them.Those are way strong,but only as strong as what the reciever is hooked to /forums/images/graemlins/grin.gif
  3. burbBoy
    burbBoy 1/2 ton status
    Feb 4, 2002
    358
    WI
    Make sure you get a good pin and not a bolt like some people ive seen. Use grade 8 bolts with washers to mount the receiver too.
  4. daleearnhardt01
    Aug 29, 2002
    3,223
    Richmond, VA
    Yup youre right there, so that pin comes out right then you put the shackle through the strap then put the pin back in? Thats what I really need to know.
  5. nvrenuf
    Jan 7, 2002
    13,079
    247
    Mobile, Al.
    I've got one like you posted (mine is a Warn), plenty strong. I've used mine and it shows no signs of fatigue.
  6. burbBoy
    Feb 4, 2002
    358
    WI
    The insert can stay in the receiver. The clevis is what you need to take out to put the strap in.
  7. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    Yes, exactly. /forums/images/graemlins/thumb.gif
  8. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    Also be sure the pin is threaded and not held in with a cotter key. Should the pin fail any extra hardware on it will turn into a projectile. The pin should thread in to the opposite side of the clevis or a nut.
  9. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    I just got one, I like it. I got an aluminum one off ebay for $24.
    "new smoke grey powder coated 2" receiver shackle bracket with d-ring.
    This unit is made of 6061 heat treated billet aluminum "
    Seller on ebay is 4x4crawler - I got this and a billet fairlead for synthetic line.
  10. jekbrown
    May 19, 2001
    45,030
    366
    Vancouver, WA, USA
    ya might find some of this info useful... gotta be safe when doing recovery ops...
    POR recovery bible
    j
  11. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I have the reciever shackle myself, but I prefer a regular ball mount and a 1" or larger clevis to that small one that fits in my reciever.
    I suppose it won't matter once I get my bumpers.
  12. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    For free you can stick the loop end of your strap in the reciever tube and stick your pin through it. Has to be at least as strong as that thing /forums/images/graemlins/thumb.gif
  13. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Can't do that with a 3" or larger strap.
  14. tomseviltwin
    Dec 23, 2001
    2,065
    Utah
    I can. Why cant you?
  15. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Dunno guess I'm special.
  16. burbBoy
    Feb 4, 2002
    358
    WI
    Wouldnt use that method all the time. If you pull to the side even a little the strap will wear on the hitch and cut the strap after a couple times.
  17. RATAH
    RATAH 1/2 ton status
    Aug 10, 2002
    576
    Franklin,Ohio
  18. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    depends on how the end of your straps are made. IF they are straigt sewn, looped, or folded loops, (all non technical names!). THe folded loop style are commonly found in winch straps/tree savers, and any of the more "high end" straps. The cheaper "keeper" straps, and anything you find at walmart/autozone/pep boys will have just a fold over, which is already a little tight sqeeze at 2", it makes it darn near difficult to attach it quickly with a 3" wide strap.
  19. daleearnhardt01
    Aug 29, 2002
    3,223
    Richmond, VA
    Im gonna bid on one of his today /forums/images/graemlins/thumb.gif 24.95+shipping. Not too shabby. /forums/images/graemlins/rotfl.gif Thanks for lettin me know Jeremiah /forums/images/graemlins/thumb.gif Hopefully a three inch strap will work with this. /forums/images/graemlins/thinking.gif
  20. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    AH, I can too, I just didn't like sticking it in the receiver then putting the pin in, I was afraid if it swept/slipped back and forth much the inside edge of the receiver would cut it if it was pulling at any kind of an angle... I worried about my locking pin bending also since the weight was centered in the middle... the receiver shackles at least distribute the pressure to the whole pin /forums/images/graemlins/thinking.gif
