Recent progress, CAGE, DOUBLER, 3-STICK, SEATS.......
Discussion in 'The Garage' started by 81jimmyslt, Mar 24, 2006.
  1. 81jimmyslt
    81jimmyslt 1/2 ton status
    Jun 5, 2003
    1,643
    So Lake Tahoe (Rubicon), CA
    Well its been a while since I have posted any progress on my truck. I wanted to start a little build up thread for some of my recent mods, so here goes.
    It all started with my broken transfer case. While it was down I decided it was a perfect time to us the WMS doubler kit I had sitting around since the sale. I looked around for some cases for quite awhile and no luck. So I called Jordan and Kyle at NWF and ordered a rebuilt 205 with 32 spline outputs, and a 203 gear box, with some bling PTO covers. NWF was a great company to work with, great products and customer service :thumb:
    I also ordered a triple stick setup from ORD, which is a nice piece of work. I ended up having to modify the center shifter slighty because of the WMS doubler.
    While all of this was going on I decided to put on the ORD highsteer and add a Rocklogic hydro assist kit as well. I did post about the assist setup so not much to mention there.
    From here I also had to ditch my broken seat in favor of a full cage, PRP seats,new 15" wheel, and some 5 point harnesses.
    More to follow.... doubler crossmember, tranny work, drivetrain install, cut and rotate spring perches, HAD shafted and e-brake, traction bar setup.
    Plenty of dash work coming in the summer too!
    If anyone has any questions, comments or suggestions, let me have it. More pics available if people want different angles.
  2. 81jimmyslt
    Jun 5, 2003
    1,643
    I order my WMS doubler kit with a 2" up rotation which worked well, I had to cut a hole in the floor under neath the passenger seat. I also didn't mention the bling Shifter knobs I got from WFO concepts, great price, wish I would have had the letters anodized though.
    I also ordered a 203-th350 adapter off of Ebay. Since the new adapter was about 2.5" shorter than the 208-350 adapter I had to pull my tranny and take it to the shop to get a shorter output shaft installed:doah: what a pain in the ass. Anyways I yanked it out and found a good shop and had him install a new shiftkit as well. I also ordered a new modulator and kickdown cable, and tranny cooler from summit.
    When I finally got everthing lined up and installed I built a doubler crossmember.
  3. 81jimmyslt
    Jun 5, 2003
    1,643
    And here is a preview of the cage more in the morning.
  4. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    SWEET!!
    HAHA I dont know what it is about cats and back seats but my cat sleeps in the same spot. Guess its comfortable:confused:
  5. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Looks great
    [side note] I am the only one who does not have a removable tranny hump??? WTFO
  6. 81jimmyslt
    Jun 5, 2003
    1,643
    HA, not my cat. She climbed in the wheel wells. I let her sleep ther until I put the PRP seats back in.
    Readymix........are you sure? That would suck.
  7. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    Mine isnt either:(
  8. NorthWestFab
    NorthWestFab 1/2 ton status
    Jan 11, 2005
    311
    Canada Eh.
    Glad to see it all coming together, looks great !!! Always happy to help !
    -Kyle
  9. stockk5
    Apr 13, 2004
    2,033
    71
    Cromwell, CT
    ohhh sick.. more cage pictures!
  10. NoReGrEtS
    NoReGrEtS 1/2 ton status
    Nov 7, 2005
    848
    Moreno Valley,SO CAL
    looks good:thumb:
  11. readymix
    May 30, 2004
    6,706
    26
    I am positive. I was going to cut it out and weld a flange with a few fasteners to it, but I started to worry about hurting the integrity of the floorpan as a whole. I am not sure if they put a few extra bends or anything like that on the ones that are removeable.
  12. rdn2blazer
    rdn2blazer 1 ton status Premium Member
    Jun 9, 2004
    16,486
    1,191
    So Cal.
    great job man.
  13. k5 krawler 50
    k5 krawler 50 1/2 ton status
    Jan 26, 2004
    1,467
    Gardnerville, NV
    That cage looks sweet, any more shots of it? Awesome progress
  14. jekbrown
    May 19, 2001
    45,030
    363
    Vancouver, WA, USA
    good looking rig and cool parts.
    As far as the trans hump goes... all should be removable. Older K5s have bolts to hold them on... later ones just use body panel adhesives. Heat gun should weaken the stuff enough that you can get it to come off.
    j
  15. koldsimer
    koldsimer 1/2 ton status GMOTM Winner
    Jan 10, 2005
    1,480
    texas
    Looking good Jesse.
  16. 81jimmyslt
    Jun 5, 2003
    1,643
    More pics coming
    As some of you may have notice the rear portion of the cage sits a little low, this is because I made it to fit with the soft top over it. I also made the cage removeable, it's two portions. The lower front seat section is one piece and the whole top and rear portion is a seperate piece.
  17. 81jimmyslt
    Jun 5, 2003
    1,643
    Here is a few more
    The rear seat will remain in place until I move back to Tahoe. Soon it will be replaced with 2 more PRP seats, then I will finish the rear portion of the cage. I still need to mount my spare tire, highlift and tool boxes in the rear as well.
  18. AZPiNsTrIpEd
    AZPiNsTrIpEd 1/2 ton status
    Jan 24, 2005
    289
    3/4Tonsville
    Damn dude, it looks like you've been busy:eek1:
  19. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    definetally been busy, awesome work man.
  20. k5 krawler 50
    Jan 26, 2004
    1,467
    Gardnerville, NV
    that cage is just plain cool, thanks for posting more pics.
