recentering hummer rims
Discussion in 'The Garage' started by josh86k10, Aug 30, 2005.
  1. josh86k10
    josh86k10 1/2 ton status
    Feb 13, 2005
    423
    Knoxville, TN
    I recently got a set of 12 bolt hummer rims with rubber run flats. I am looking to recenter them and was wondering everyone's opinions.
    Where should I get my new centers? I like the fact that the USA6x6 ones are "pressed", but how much does that really matter? My truck will see the highway some.
    Should I send them off to be recentered or just buy the centers and have them done locally at a machine shop?
    How necessary are rock rings (like the ones Diy4x sells)? Do H1 wheels bend easily?
    How much backspacing would you recommend? I'm going to run 39.5x15x16.5 TSL's on 6" of lift. I would like to keep from moving the axle forward if possible. Is this possible without moving the axle?
    And finally, should I run the rubber runflats? I won't have a spare for a while, plus they're already there.
    A lot of questions, I know. Thanks in advance.
  2. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    I just finished up recentering my h1s. I bought the centers from 6x6 and new orings. I was going to do 3 1/2" backspacing but when I got into it, the new centers will sit flush on the lip @ 3 3/4" so thats what I went with. I just cut the old centers out and welded in the new ones. I've got the mag runflats but I cut the back bone off. I've heard that the rubber inserts are more trouble than any of the others, I don't know. I still haven't mounted the tires on yet but maybe this weekend.
  3. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    Here are the USA 6x6 centers with 39.5" tsls
  4. josh86k10
    Feb 13, 2005
    423
    Knoxville, TN
    Did you have them recenter them or did you do it yourself? Did you keep the runflats or go PVC? What backspacing did you go with? Any chance you could post a picture of them mounted on your truck, so I can see where the tire sits in relation to the fender with whatever backspacing you decided on?
    Thanks,
    Josh
  5. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    I have a setup that you don't need to recenter them...it comes with hubs and a fitted spacer that you bolt the rim to...if you have the dana 60 front I also have the DRW hubs...I'm moving to a new house and I'm trying to clear some stuff out...
  6. josh86k10
    Feb 13, 2005
    423
    Knoxville, TN
    I'm interested. What kind of money are we talkin' about?
  7. Mudstud
    Mudstud 1/2 ton status
    May 29, 2001
    1,472
    Memphis, TN
    Tony's wheel spacers
    I'm interested in the spacers also. I'm running a van width 14 bolt on a 76 K5 and have the hummer rims ready to go. Some questions:
    What are they made of?
    How wide is each one...for my application?
    Hardware included?
    How can I contact you besides this board?
    Price and shipping to 38135
    :bow:
    Best email to reach me is dkrier@usps.gov
    Thanks, Dan
  8. project84k5
    project84k5 Registered Member
    Sep 14, 2004
    40
    Fort Worth, Texas
    i have 15x39.5x16.5 tsls on hummer wheels with spacers and 6" of lift and my front axle is moved 2" forward and my rear is moved back 3" and i havent rubbed yet, but i do have long bumpstops. but when i go slap on the 42s it does rub quite a bit, and you can forget about not cutting the fenders, its a must. just my 2 cents.......
    ryan
  9. Mudstud
    May 29, 2001
    1,472
    Memphis, TN
    You running a van width 14 bolt? How thick are your spacers? I have a 6" lift also.
  10. blazin_blazer
    blazin_blazer 1/2 ton status
    Aug 2, 2005
    4,043
    central arkansas
    i was told...
    that a drw spacer will work also!
  11. project84k5
    Sep 14, 2004
    40
    Fort Worth, Texas
    no its not a van width, just a standard pickup. believe it or not i am running 3" spacers :eek1: , but it clears everything, doesnt rub the fenders or the springs. it actually makes the hummers 7" of backspacing 4", just like most 15 and 16 inch wheels. ive never had a problem with the spacers or with bearings, so i have no plans to throw them out. its just key to check the torque on the spacers quite often since they are aluminum and everything else is steel.
    ryan
  12. blazin_blazer
    Aug 2, 2005
    4,043
    central arkansas
    where did you get you spacer, i was told to use a drw spacer to get them to fit.
  13. jays68yak
    jays68yak 1/2 ton status
    Feb 27, 2003
    973
    Gilroy, CA
    I did the same thing with my h1s and the pressed centers. Did it myself and I have no issues with them. THey are pretty staright but off by a tad. No biggie for me since they are trailered everywhere.
