Reciever Hitch
Discussion in 'The Garage' started by nemesis_pyros, May 16, 2005.
  1. nemesis_pyros
    nemesis_pyros 1/2 ton status
    Mar 24, 2004
    229
    Winnipeg, Manitoba
    Hi guys i got some questions regarding a reciever hitch for my jimmy.
    Do i have to get one specifically for a fullsize jimmy or blazer?
    If not what other vehicles would have a reciever hitch that I could mount to my jimmy.(one that is the right width)?
    And also would a class 3 hitch be sufficient for pulling out and getting pulled out?
  2. dyeager535
    26,977
    Believe it has to be for a k5, IIRC the frame has a downward dip that only affects the last two bolts that hold it to the frame, so the front bolt surfaces are flat, the rear are angled, and most hitches/frames are flat in both locations.
    I've dragged fullsize cars out of ditches before using only the little slots in the hitch itself (instead of the stinger) so I suspect up to a point a receiver will work fine for recovery. I wouldn't be surprised if a couple of real hard jerks during recovery might rip the frame though.
    Bad thing about at least the stock hitches is that they do a fair number to hurt your departure angle(think thats right) because they are made to fit under the stock bumper. One of the newer "tubular" ones might allow more clearance at the corners, but it still costs you probably 4" right in the middle, if not more. I know starting up and cresting steep mounds the center always drags. Not an issue in dirt, on rock it may be a bigger issue. Makes a great point to use a floor jack though! :)
  3. fireplug
    fireplug 1/2 ton status
    May 3, 2005
    1,692
    Toronto, Canada
    A class 3 is sufficient for recovery assuming recovery is performed correctly. Meaning slow and steady with hard links (wire rope/chain/static straps) or preferably with dynamic snatch straps. Although I wouldn't use the safety chain loops! Buy a proper shackle attachment that slides into the receiver. My Warn winch is a factory Multi Mount that fits into either my front or rear receivers.
  4. nemesis_pyros
    Mar 24, 2004
    229
    Winnipeg, Manitoba
    Thanks for the info guys
    guess I shouldn't have been yanking so hard with the original hitch :blush:
    oh well live and learn.
    I'm gonna find something the right width and beefy then fab it up to make it work.
  5. Boondocks
    Boondocks 1/2 ton status
    May 10, 2005
    129
    Massachusetts
    I installed at weld-on unit a few years back on 72 K5. I have not performed a recovery with it, but I did pull a stump with it using a shackle.
    Yes, it does lower my departure angle, but the crossbar will make a slick rear attachment point for my new skid-plate to cover the 37 gallon tank.
  6. Jagged
    Jagged 1 ton status
    Apr 25, 2005
    11,460
    SWVA
    My 87 K5 has a class III receiver on it (was there when I bought it). I've been snatched by the hitch a few times and it's held up fine. Heck, the first snatch I did with it was with a big chain hooked up to it, and it was getting tugged on by a Z71 Silverado and he had about a 2-3 foot running start.
    Been dragged sideways with a tow rope attached to the receiver... all in all I say it's held up well so far.
  7. fireplug
    May 3, 2005
    1,692
    Toronto, Canada
