Recirculation vent motor tapping? HELP HELP
Discussion in '1992-Present Chevy & GMC models' started by blzr4x4ngkid2, Sep 20, 2003.
  1. blzr4x4ngkid2
    blzr4x4ngkid2 Registered Member
    Jul 20, 2003
    92
    Wichita, KS
    It started "tapping" every time I turn on the air, and even when I don't have it on. I've narrowed it down to the "rec/max" vent on the passenger side floor board. Now the question is, has this happened to anyone else and what did you do? When I say tapping, it sounds like there's a little munchkin tapping on the dash with a screwdriver. I'm sure it's the teeth stripping out. Basically, the relay motor for the vent flap doesn't know when to stop turning and that's causing the tapping. HELP!! I want to fix it myself, but if I can't then I need to get it to the shop.
  2. chebywanna
    chebywanna 1/2 ton status
    Apr 20, 2003
    277
    streamwood, (chicago)
    i HAVE the same problem, if you stick your fingers in there and hold it up a little youll notice that it pushes real hard, i have no fricken idea why they made it push so hard, and it only stops pushing after some time.
    the way i "fixed" mine is i stuck a nut inder it, or between the cross hatch and the flap door, basically stops it before it gets down to the stripped teeth. true it doesn't seal up anymore but hey, just can't use rec or the nut falls out, but could glue it on, or dock tape it on /forums/images/graemlins/thumb.gif /forums/images/graemlins/rotfl.gif
