Recommend me a rear sway bar
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by YtseJam, Nov 23, 2002.
  1. YtseJam
    YtseJam 1/2 ton status
    May 19, 2002
    147
    CT USA
    I have an 88 K5 that I have added rear 2" spacers to help the rear stability. I have also replced all of the shocks. I was thinking of adding a rear sway bar too. So my question is to those of you that have installed them. Did you notice a big difference? and where did you get yours and how much $ Thanks!
  2. big d
    big d 1/2 ton status
    Oct 24, 2001
    1,236
    illinois
    i got mine from jcwhitney. i believe it was a hellwig. i have yet to install it but it has to help.it is just one item in a long list i have to bolt on to my rig. /forums/images/graemlins/grin.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/1zhelp.gif
  3. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    I've got a front one that I'm adapting to the back... but don't have mine on yet either, still making the disconnects for it.
  4. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    whats wrong man? dotn like pulling up the left front?
    Grant
  5. BorregoK5
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    Thats part of it, but I want to try the 57" Ford rears up front. I wanted flexibility in tightening it up if it turns out to be too loose on the streets.
  6. CrazyCoot
    CrazyCoot Registered Member
    Nov 24, 2002
    25
    Redding, CA
    I had a 1" bar on the rear for a while. Good chance a front bar will be too stiff for the rear. Too large will cause understeer. One other thing to think about....the front bar is shorter over all and the "arms" (can't remember the correct term) are also shorter making it much stiffer than a stock rear bar of the same dia.
    Just a suggestion.
  7. BorregoK5
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    Very good points. I'm not too concerned with the stiffness aspect as I can build spring loaded play in the rods that connect the swaybar to the axle and simulate a softer bar. Getting an unobstructed swaybar to cycle up front with cross over steering will be the trick, so I may only be able to run the rear one at first.. so stiff might be better in the short term. /forums/images/graemlins/grin.gif
  8. Seventy4Blazer
    Apr 21, 2001
    5,634
    Escondido, CA
    yeah, i was thinking about putting my 52's up front. maybe ill do it this week.
    are you going to use the 3 inch wide 57's? or the 2.5 inch wide 57's?
    Grant
  9. BorregoK5
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    The 3" wide ones might be a better match, but the 2.5's will probably flex better.. or too much! I'm still up in the air.
