Recommendations on 6" springs. Almost purchase time
Discussion in 'The Garage' started by Desert Rat, Feb 9, 2003.
  1. Desert Rat
    Desert Rat Fetch the comfy chair
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    Recommendations on 6\" springs. Almost purchase time
    Ok, I've gone back and read all the posts I could find on Tuff Country and BDS springs. Here is the specs on my rig I'm building. 14bff in the rear. D60 going in up front. 4x4Iron rear bumper in the future w/ tire carrier and lots of gear to be bolted on. Front bumper from SEC, 4x4Iron or someone else w/ Warn winch. Interior will be stripped and Line-X'ed and has a full roll cage but hauling a lot of gear. Most of my trips tend to be hunting, or exploring. The rig probably won't see the Rubicon but may play at Hollister and Carnegie on occasion when empty. My wheeling tends to be desert exploration w/ creek running and canyon crawling on rarely used trails. The back will be full of camping gear, ammo, and other stuff.
    My question then is, what 6" springs should I go for? Will the Tuff Country EZ rides be too soft for all my gear? How about the BDS? I also have the ORD shackle reversal in the rear and HD ORD spring hangers up front. So 6" up front w/ 2" springs in the rear was the plan. I suspect several are running this combo. Should I do the TC heavy duty springs or will they be too stiff?
  2. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    Re: Recommendations on 6\" springs. Almost purchase time
    All I can tell you is NOT to buy Genuine Suspension, ProComp, or Ranchos.
    -- Mike
  3. florida4x4
    florida4x4 1/2 ton status
    Sep 9, 2002
    255
    Florida
    Everybody I trust tells me to stay with Skyjacker or Superlift as a backup...
  4. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    My friend has teh 6" Skyjacker Softrides on his 72 K5... there is nothing soft about them.
  5. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Allright, to actually answer your question.....
    Both choices you listed are good ones. Personally, I'm looking into some BDS front springs for my truck because I haven't heard a bad thing about them. I'd say go with the Tuff Country H.D. if you go with T.C. With that extra weight from the front bumper stuff, you'll want those springs so you get the full lift you're looking for. Going with the T.C. Heavy Duty's will probably get you in the same spring rate range as the BDS springs. Just a guess though. I know BDS 4" front springs have a spring rate of 425, and the T.C. HD's are 395 in the 4" variety - so I'm assuming you'll see a similar comparison in the 6" springs. Overall, if I were you, I'd go BDS for one main reason: since both springs are great quality/very comparable, why not buy the springs with the unmatched warranty that BDS has? Go with BDS.
  6. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Go for the BDS !!!!!
  7. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    I am also getting ready to purchase springs, Every bit of research I have done sends me right to BDS. I am going to use there 6" rear springs up front.
  8. Desert Rat
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    What are you doing in the rear? I have the ORD shackle reversal and would prefer to stay away from blocks.
  9. bablazer73
    Apr 4, 2000
    3,363
    upstate ny
    for now, I have 2" Rancho springs,shackle reversal and 4" blocks. I plan on going with BDS 6", 56" springs in the rear and dump the blocks. But going to do front over first.
