Recommended gearing for 33's
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Blazin Ed, May 19, 2003.
  1. Blazin Ed
    Blazin Ed Registered Member
    Mar 29, 2002
    92
    Seattle
    Recommended gearing for 33\'s
    I plan on getting my '88 K5 regeared pretty soon... I'm running 33's with a 4" lift. I believe I currently have 3.08's installed so it's pretty sluggish on take off. What would you guys recommend I regear to with my 33's. I'm planning on taking it Randy's Ring and Pinion since I live in Seattle... Any word on them?
    Most of my driving would be 60% hwy, 40% city with occassional towing of a 18' boat, about 2500lbs.
  2. tRustyK5
    Jul 23, 2000
    36,179
    1,387
    E-town baby!
    Re: Recommended gearing for 33\'s
    Go with 4.56's...you won't regret it. It'll tow very well and with the overdrive will do just fine on the freeway too. In town it should have plenty of snap too.
    In my opinion GM made some major blunders with gearing in the 80's. No overdrive tranny equipped truck should have got anything less than 4.10's. The standard tire size was 31" and 4.10's would have been just fine...For 33's I think 4.56's would be perfect.
    The extreme low rpm's you get with 3.08, 3.42's and even 3.73's and the 700R-4 lead to premature tranny failure and generally very poor acceleration. Deeper gears will help you almost everywhere. Acceleration, tranny life, towing, and most likely even mileage. A motor that's lugging doesn't give the best mileage.
    For additional info, have a look around this forum and the Garage...the subject has been covered more times than I can remember and there are at least 3 other current posts about gearing.
    Rene
  3. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    Rene summed it up very well i would recommend 4:56's as well /forums/images/graemlins/thumb.gif
  4. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    Rene, I've got to disagree with ya here. Ya probably read my other post on this subject. I never had tranny problems with my gearing and the accelaration was awesome. I wouldn't want to tow anything bigger than a small trailer with those gears and the hills could be rough, but the 3.73 won't wreck the tranny.
  5. Big Red
    Big Red 1/2 ton status
    Jan 9, 2003
    250
    Bristol, CT
    I agree with Bubba Ray. I've got the 3.08s and my truck is just fine around town and the tranny is still like new(yes its the stock tranny) The only fault i can find is i can't smoke them as often as i would like, but we all know how to fix that problem. /forums/images/graemlins/grin.gif
  6. Scott73
    Scott73 Registered Member
    May 22, 2002
    38
    Electra, TX
    I have 4.10s and am happy with them.
  7. mrhoes
    mrhoes 1/2 ton status
    Jul 20, 2002
    123
    Austin, Texas
    if it was me i would go to 4.56 or 4.88
  8. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    4.56's with 33's
    4.88's with 35's
    5.13's with 37's +
  9. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    thing is, everyone also says dont tow in OD. if you think about it, third gear would be 1:1 ratio, and you'd be spinning pretty high- a lot of the mph when I travel is 70mph speed limit.anyything less than 65mph and your gonna get rear ended. I tow 4000;bs with 33 and 3.73 in third gear, and in od if it is perfectly flat and not switiching around. 4.10 would be more ideal, and also pretty decent for 35" if you move up. but at that point, axle strength becomes an issue, so maybe worthwhile to get a different axle at that point.
  10. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    My neighbour's running a 396 in his '80 K20 with a Dodge (Getrag) OD trans. Tires are 285/75R16 (33?) and 3.73 ratio. He finds OD too tall... never uses it around town - strictly a highway gear.
    Also consider the likelihood of upgrading to stronger axles, lockers, and the possibility of losing OD should you swap to a stronger trans/tcase, or even upgrading to dual t-cases. /forums/images/graemlins/thumb.gif
    FWIW, I changed my daily-driver (Burb) from 4.10 to 3.21. Excellent swap for my situation. To each his own... everyone has different needs.
  11. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    33s and 4.56s you will be revving pretty high on the freeway. At 65 mph you will be reving about 2150 rpms, but thats with no slipage and a trus 33" tire. When I had 4.56s and 35" MTR (which measured 34") I would have to cruise down the freeway close to 2800 rpms to keep up with traffic. When I put 38.5s on my old burb with the 4.56s, it cruised down the freeway better. I would say if you do alot of freeway, nothing more than 4.10s. 4.56s are great for city driving though. Also remenber that you arent supose to tow in OD, so if you put 4.56s in it with 33s and in drive you will do 65 mph at 3100 rpms. 75 mph is over 3500 rpms /forums/images/graemlins/blush.gif
    I towed my race boat with my burb on 35s (4.56 gears) in OD beacuse I couldnt keep up with traffic if I didnt, but I had a GM certa 700r4 and a built 350.
    Dan /forums/images/graemlins/k5.gif
  12. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    Randy's is definitely one of the best in the business. You are luck to live near them. /forums/images/graemlins/thumb.gif
    -Harrison
  13. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    Doing the same thing minus the boat towing and I'm moving from 3.08's to 3.73's, I think anything higher will run to high on the highway. I personally wouldn't go higher than 4.10 unless your running big tires (35+), I'm going to use 3.73 I think with the 700r4 it would work out better (I'm going with a LT285/75 -true 33" tire, 11.5" inch wide). Just my two cents though!
    Ask the pros when you take it in! /forums/images/graemlins/thumb.gif
  14. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I have said it time and time again. 3.73 is not enough gear for 33" tires.
    Run 4.10s if you want to keep your 33s, 4.56 if you plan on at least going to 35s, and run 4.88s if you ever intend on going larger than 35s.
    Too much gear isn't bad. Too little sucks.
  15. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,085
    486
    Grand Rapids area
    My opinion is 4.10 for 33's.
  16. Blazin Ed
    Mar 29, 2002
    92
    Seattle
    Wow! Sounds like a lot of ya are leaning towards the 4.10's but there's also been some excellent reasoning on why the 4.56's are a good choice as well. If I only tow my boat a half-dozen times a year (less than 300mi) than the 4.10's might be a better all around choice for the 33's since I do a lot of freeway driving.
    I'll also talk to the guys at Randy's and see what they recommend based on my vehicle use. I liked jjlaughner's quote "ask the pros"!! I'll let everyone know which way I went and how it turns out! /forums/images/graemlins/k5.gif
    Thanks!
    Ed
  17. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    If your going to change gears, minimum 4.10 or 4.56
    Try the calculators on this page http://www.4lo.com/ and see what you get.
    Im running 32's on mine with 3.73 and will go to 33's. IF I was going to 35's, I would go a minimum 4.56
  18. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    whats all this about not towing in overdrive? is that an old O/D trans thing? because gm says its ok to tow in OD with the new trucks...
  19. RootBreaker
    Nov 29, 2001
    5,118
    173
    Williamstown, NJ USA
    well when i had 33's and a turbo 400 i had 3.73's and np203 full time xfer.... NEVER and i mean NEVER had problems towing nor wheeling.... that is what low range is for if you need it......
    but then i bought another truck.. rolling chassis with 4.56's and smc465 trans and np205 xfer.....
    i actually got better gas mileage cuz i went from full time 4x4 to part time with locking hubs.... but went to lower gears.... i could pull down a house with the 4.56's and creeper gear.....
    so if you have a daily driver and dont tow HEAVY HEAVY stuff i would say 3.73's... had no problem hitting 120mph with the truck with 3.73's
    if you have a weekend warrior.... or expect to tow another heavy vehicle... i would go the 4.56's....4.56's down the highway ate more gas though..... but could only get the truck to 100mph......
  20. u2slow
    May 9, 2001
    2,217
    BC Canada
    The new trucks have a "tow/haul" mode - a button you push somewhere on the dash or column (can't remember which). It probably turns off OD regardless of the shifter position... or it only enagages OD when its completely safe.
