Recovery Hooks?
Discussion in 'The Garage' started by Hossbaby50, Oct 27, 2004.
  1. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    How strong are the standard generic tow hooks? I am trying to figure out what I want to do for hooks/shackles on my new front winch bumper.
    I am running a Warn 12000lb winch and I need something that will be strong enough to handle a double line back to the truck if I need to do so. I am thinking that the generic hooks will just turn into missles if I use a winch that big on a double line or a hard snatch.
    What are the opinions and options.
    I am also thinking about weld on shackle tabs but I wonder how strong they can really be with only a few inches of weld surface. The welder I have access to is a Miller 135 with .030 flux. I can weld pretty well so I am thinking this is the best route but still wonder if the welds will be strong enough.
    Harley
  2. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    I hate using hooks, they scare me since the line could slip off.
    I like using big heavy shackles, if you are worried about your welds just cut a hole through the bumper and run some square tubing to the frame and bolt it to the frame and weld it to the bumper, then just drill a hole in the tubing and use the shackle.
    /forums/images/graemlins/thumb.gif
  3. dhcomp
    dhcomp 3/4 ton status Premium Member
    Mar 17, 2001
    9,862
    295
    Truckee, CA
    IIRC, you aren't supposed to weld recovery hooks. Yes, welds can be strong enough, but its hard to tell if they are strong enough until you rip one off. If the hook is bolted on, you know how much force teh bolts will take before they break.
  4. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    thats why I say do both for worry free strength /forums/images/graemlins/thumb.gif
  5. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    I made mine around 18" long both front and rear and they are bolted to the frame with 3 bolts and welded to the backside of the bumper.
  6. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    I am not going to weld the hooks on. I would use 2 grade 8 bolts but I am affraid the hook itself might break.
    If I weld on a shackle tab it will be like this.
    I am looking for opinions and options for what will work and what is safe.
    Harley
  7. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Whats your new bumper look like?
  8. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    Not sure, it isn't done yet. right now it is just the winch box. It is 28"x14" deck, 4"x13" side plates, and 2"x28" front plate below the deck.
    Harley
  9. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Why not cut a square hole in the bumper and extend the mounts clear back to the frame and bolt them to the frame and weld them to the bumper.
  10. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Have you looked at the new Superduty hooks? Or rather loops to be more accurate. Forged U-shaped things that are sort of like a rigid d-ring and bolt to the frame. Or CUCV type shackle mounts that are not even part of the bumper. I kept my old ones with just such a thought...
  11. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    Harley, how soon are you putting the tabs on? Is the bumper mounted at all yet? If so we bounce ideas around this weekend. I ahve a couple that will work with the big azz cradle your 120000 needs. As for the welding of those tabs, mine are welded with a 110V flux. I did preheat it, and cut open the back of the mounting plate so I could double the weld surface. I have been tied to fred with them, dragged through woddy's wash & terminator twice. So far no problems and I have inspected them heavily.
  12. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    The cradle is already mostly completed. I haven't done anything on the tabs yet. I will need to order them if I go that route. I can wait till Sunday. I should have the bumper mostly completed and mounted by Sunday hopefully.
    Harley
  13. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    well as to how strong the stock tow hooks are very strong, i buried a tow moter in a foot and a half of soggy gravle and yanked it out with the stock hooks on my sub, very hard pull, slightly bent the one but barely.
    heres my front bumper with 4"x5/8" flat for shackel mounts /forums/images/graemlins/waytogo.gif
  14. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    i like the stock bolt on hooks. they've got a pretty good bend to them, i've never had anything slip off. i doubt you could even bend them while winching. shock loading is whats hard on stuff like that.
  15. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    Either use a pass-through D-ring (A D-ring that bolts to the frame) or 88-98 IFS hooks.
    I'd make a D-ring that is long and bolts to the frame and then weld the bumper to that D-ring.
  16. az-k5
    Oct 15, 2003
    2,774
    Phoenix AZ
    I think I have some of those IFS hooks for you. Freebie.
