recovery shackle mounting question
Discussion in 'The Garage' started by big83chevy4x4, May 6, 2004.
  1. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    im currently building a tube front bumper. im using 1/4" mounting. i plan on using 3/4" for the shackle mount, one reason is my dad needs 2"x6" of 3/4" for his plow, and i though i would just buy some more and use that.
    what i want to do is have 1/4" machined out of the center the long way and put the bumper mount in the gap and weld it all the way around both sides. will this be strong enough?
    i think it will hold better than just slaping it on the side and weld one side, because there is twice as much weld. my consern is streching the 1/4" /forums/images/graemlins/thinking.gif /forums/images/graemlins/thinking.gif
  2. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    I think it would serve a similar design if you cut the 1/4" plate to slide the 3/4" block in too. I don't see streching the plate as a problem as long as the bolts are not to far away. I would be more worried about side loads though.
  3. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    right now, where the bolts are going is about 8" away from the front, but i will cut about 4" or 5" from the front, as it sticks out that far from the main tube. the design will have plenty of support between the frame and the ends on the bumper. im kinda copying derf00/bullet's front bumper /forums/images/graemlins/waytogo.gif
  4. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    also whos got the best deal on 3/4" shackles? i need 2 now, and 2 more in about a month
  5. stock93
    stock93 Registered Member
    Feb 18, 2004
    68
    Huntsville, AL
    I'm building a custom rear bumer with two 3/4 in shackles. Would it be any problem if I just used 3/4 x 4" to mount it the bumper to the frame and ran it out to the shackle? I figure if I get hit or hit anything the frame is going to bend first /forums/images/graemlins/frown.gif
    John
  6. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    how about tieing the 3/4" plate from the frame, through the bumper and also used as clevis mount? that is how i made mine, it make a lot of sense IMO
  7. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    the 3/4" is $$$ so im trying to use as little as posible, but enough to be safe. i might do that but wanted an opinion on what im thinking
  8. GMCLegacy
    Jan 24, 2002
    620
    Grand Haven, MI
    those extra bucks is worth it compared to worrying about some weld breaking.
