Recovery Strap ?'s
Discussion in 'The Garage' started by stockk5, Jan 6, 2005.
  1. stockk5
    Apr 13, 2004
    2,037
    73
    Cromwell, CT
    I got a few quetsions
    1.Whats is the right way to hook a strap up to a truck that doesnt have D rings or hooks?
    2. Anyone got pics of how there D rings are hooked up to the frame for a blazer or chevy truck?
    I dont have any brakets welded on to mount my D rings yet and last night i almost had to pull a friends car outta a ditch cuz of the snow. So any tips would be helpful.
    I am looking into buying some pro-comp straps of my own. Also, why should i get 2, just for a back up or is it better to hook up 2 straps at once to pull someone out? thanks for the tips, Mike
  2. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    You got a trailer hitch? If you do you can get an insert that has a D-ring on it. Thats what I use....
  3. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    What about taking out the 5/8" hitch pin, putting the loop of a strap in the receiver, and putting the pin back in through the loop? Is this ok or a no no?
  4. stockk5
    Apr 13, 2004
    2,037
    73
    Cromwell, CT
    anyone else?
  5. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    I've used that many times.
  6. Fubeca
    Fubeca 1/2 ton status
    Dec 18, 2002
    2,100
    Denver Area
    Here's my 2 cents.
    1) There isn't really a right way to hook a tow strap to a vehicle that doesn't have rings or hooks. If it is an emergency in the snow and you are careful not to yank -- you might be alright by hooking to something solid like the frame or an axle. However, if you are good and stuck hooking to anything that isn't designed for the load is just asking for trouble.
    2) Sorry I don't, you can get stock recovery hooks for blazers and trucks very cheaply at a junk yard or on here in the parts for sale section. They mount to the frame in the front. (They are still pretty weak IMO -- I've sheared a bolt on mine and just about had some issues :crazy: ).
    3) Two straps are nice. It is nice to have a backup in case one gets damaged, and often you can't get close enough to the stuck vehicle so it is nice to have the extra length. I am not aware of another reason that it would be better to connect two straps. In fact, the method of connecting the straps can create a weak spot making the combination strap weaker than the rating of either strap by itself.
    *Edit*
    I have also used the "stuff the strap in the receiver" method. If your receiver has rough edges it is a good idea to cut a section of a bike tube to thread your strap end through -- then the rubber from the tube will help protect your strap where it contacts the reciever.
    Hmm -- I guess I am long winded and boring -- I better apologize to my wife :D
  7. zeroz400
    zeroz400 1/2 ton status
    May 30, 2004
    410
    Libertyville, IL
    Ive used the hitch pin countless times. If you dont care about your bumper you can make a slipknot around it and hook the other end to another vehicle. Also, if you do lots of mudding, the more straps the better! We used to go to a swamp and get stuck and we'd get the V10 F250 to pull us out. We had to keep the F250 on dry ground so we had 165ft in tow straps, you can never have to many.
    Later
  8. sweetk30
    Nov 1, 2004
    25,554
    547
    horseheads , ny 14845
    strap info
    explorer pro comp 3" work vary good . and are folded and wraped in lether at the ends. thay fit just perfect in the standered 2" recivers we all run on our rigs. the pin methed has worked 100% for me and i think is the best and easyest. you can usally find them for 55-65 dollers.:grin:
  9. 85burbanator
    85burbanator 1/2 ton status
    Feb 10, 2003
    577
    lake orion, mi
    before i got some stock tow hooks for the front of the burb i always used the reciever. still do but since i got the blazer the burban is only used to help people out of ditches and stuff. i have over 100' of tow strap in my truck. 1 3x30 pro comp strap, 1 2x15' foot keeper strap(2 for 10 bucks 1 got stollen along with a 6x30or40 pro comp strap), 2 military tow straps 2x30' i think. they are long, and strong and down to get the freak **** awn. mikey got straps.:D
  10. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    No offense, but that's just about the worst possible way to hook up a nylon tow strap.
    1. Stock bumpers make terrible pull points. The bumper itself is flimsy, and by now the stock hardware is at least 15+ years old and generally rusted to hell and back, making it extremely weak. About the only thing worse than a bumper flying through the air at the end of a 30-foot "rubber band" would be a trailer hitch ball...
    2. Felt the edges of a stock bumper lately? That edge is like a sawblade to a nylon strap under tension. I don't know about you, but I've got better things to spend my money on than replacing towstraps that died long before they should have. Especially when doing it right isn't very hard.
    I killed my first strap in 3 wheeling trips because I used the hitch-pin method, and the receiver opening cut the strap eye too badly to use anymore (my own fault - shoulda looked at the receiver closely before doing this, but I was a newbie at the time and didn't think enough). Do yourself a favor and get a reciever shackle bracket. Or a receiver tow hook. Or even a receiver tongue with as little drop as possible, and put the pin of a D-ring shackle through it. It's better than nothing, and far better than some of the other alternatives.
  11. Drey
    Drey 3/4 ton status
    May 8, 2003
    8,288
    Iowa
    What about wraping it around the square tube on the Receiver hitch?
  12. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,030
    858
    Pinckney, MI
    knots and its a pain the the butt. Not to much clearance between bumper and reciever hitch. On my truck its about 1/4 of an inch. broke my first strap that way.
  13. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    Me too.:cool1:
  14. k5floyd
    k5floyd 1/2 ton status
    Feb 6, 2004
    313
    Friendswood, Tx
    i broke both my 3" and 2" pro comp strap first time out. but i was pretty good 'n stuck. mud has a suction force like you would beleive, ill tell ya.
  15. WantedaDodge
    WantedaDodge 1/2 ton status
    Dec 16, 2004
    282
    Eugene, OR
    are the 2 inchers strong enough for rigs under 5000 lbs?
    Are the blazer frames driller for two hooks stock? I put some tow hooks on a buddies Exploder and drilling throught the frame was a bitch. If I can just bolt them on though, I'll buy some and some Grade 8 hardware!
    how much does a reciever D Ring cost?
  16. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I don't know about 2 inchers , but my 3 inch and 30,000 lb one is only rated at 10,000 working load . So I wouldn't use less than that whether the truck weighed 2500 lbs or 5000 lbs or 10,000 lbs . More is always better with these , I am glad I have recovery gear now , and already helped a Furd :k5: :k5:
  17. folkenheath
    folkenheath Worthless Trash Premium Member GMOTM Winner
    Nov 12, 2004
    4,269
    159
    Wisconsin
    If you have a 2" receiver, go to Farm and Fleet or somewhere and get the lowest drop (2") hitch, and a clevis, make sure you use hardened pins. For the front, get some factory tow hooks, use good grade 8 bolts. The frame is drilled from the factory on all 4WD GM trucks as far as I know.
    Respect the tow strap, it has a lot of stored energy when stretched.
    Also, I have seen a stock rear bumper ripped clean off before with my own eyes (OK, I admit it was a Ford that the bumper flew off of), so don't wrap it around a bumper. Luckily the the bumper just flew (very quickly) into the back tires of the truck pulling it out, no one was injured.
    Have fun and be safe! :smile1:
  18. Drey
    Drey 3/4 ton status
    May 8, 2003
    8,288
    Iowa
    I was talking about the Receiver hitch on my 96 S10 blazer, I have a bit over an inch of clearance between rear bumper and receiver hitch. On my pickup I have a DMI Ag Hitch so I use a clevace and farm style hitch pin.
