Red and Green coolant. Same thing?
Discussion in 'Other Rides' started by MilpitasK5, Apr 26, 2003.
  1. MilpitasK5
    MilpitasK5 1/2 ton status
    Nov 13, 2001
    889
    Milpitas, Ca.
    Hey all:
    Kind of a dumb question but my pops got a 93' Cadillac used and we just had the water pump changed. (I don't know why he went to a mechanic..) We got the car with orange/red coolant and the mechanics put Green coolant in it so it's mixed.
    Do we have a problem??
    Thanks,
  2. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    Me personally, that mechanic needs to drain it out, and refill it with the color it came with. Sounds like a case of being a lazy butt. The odds are slim, but it could cause corrosion, make the antifreeze not work for as long as it should (shorten the life because the chemicals broke down too soon), and even cause water pump issues. Orange is that organic acid antifreeze which is for the aluminum radiator I believe. There's even different types of oranges from what I understand. I dunno.... maybe I am off, but I was told on my moms Honda, to always use blue which it came with, and nothing else. So I do. I think there maybe a green out there that is compatiable with the orange ingrediant wise, but you'd need to check that for sure. Maybe this was the case. Try to find out and do some looking on the brands to make sure. I swear, anti freeze is freaking confusing anymore... /forums/images/graemlins/tongue.gif /forums/images/graemlins/grin.gif
  3. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    No there not the same. The only problem it will cause is that it will break the two types down quicker and shorten the life of the coolant. IMHO that red stuff is junk.....it gets gummed all up and its just a mess.
  4. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    The red coolant is the GM dex-cool stuff. Your car is designed to run that kind of coolant, not the standard green stuff.
  5. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    Plus it all looks brown mixed together...YUCK!
  6. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    I thought that the red is extended life. /forums/images/graemlins/1zhelp.gif
  7. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    Flush it out now. You need to run a hose and get all if out as fast as possible. The two coolants are not compatible, and actually turn into a mud like substance. It will end up cloging your radiator, heater core, and even the engine.
    Dan
  8. jeffer
    jeffer 1/2 ton status
    Nov 6, 2000
    113
    Loveland, Colorado
    Yeah, the red is GM's Dex-Cool, extended life..... Everything that I've heard says that mixing the two types is bad-juju. Mixing evidently causes the coolant to break down with not so good results. I made this mistake by putting some of the the red stuff in my blazer and now the heater core doesn't flow worth a hoot. Possibly gummed up in there. I would take it back and ask him to flush it and replace it with the correct coolant.
  9. MilpitasK5
    Nov 13, 2001
    889
    Milpitas, Ca.
    Thanks everyone!!! I'll get that taken care of!
  10. balzackks84
    balzackks84 1/2 ton status GMOTM Winner
    Aug 22, 2002
    1,344
    portland, oregon
    All I can tell you is they're different. /forums/images/graemlins/thumb.gif
  11. MilpitasK5
    Nov 13, 2001
    889
    Milpitas, Ca.
    LOL not if you're color blind!! /forums/images/graemlins/deal.gif
  12. oatsk5
    oatsk5 1/2 ton status Premium Member GMOTM Winner
    Aug 18, 2002
    1,724
    8
    Grand junction CO
    The way its been explained to my is that its for aluminum heads ? i know my Grand prix gt has dex cool i wont runn anything but dex in it the mixture has been known to cause gumming / mud like junk. /forums/images/graemlins/thumb.gif
