"Red Hot"
Discussion in 'The Garage' started by 82_k5, Oct 26, 2004.
  1. 82_k5
    82_k5 Registered Member
    Oct 3, 2003
    94
    \"Red Hot\"
    I have a problem and I've never heard of it before. My Blazer with a 350 motor and dual exhaust is getting really hot. It is dark out here and I opened the hood because it smelled hot, to my suprise both exhaust manifolds were glowing orange. They are off of a 305 so the only thing i can think of is that they are too restricted??? /forums/images/graemlins/confused.gif /forums/images/graemlins/1zhelp.gif I really don't know what to do.
  2. blazerpunk
    blazerpunk 1/2 ton status
    Feb 3, 2004
    121
    Trinidad, CO
    Re: \"Red Hot\"
    Do you still have cataletic convertors? /forums/images/graemlins/dunno.gif
  3. 82_k5
    Oct 3, 2003
    94
    Re: \"Red Hot\"
    nope, no cats, it has new mufflers so that shouldn't be a problem either. /forums/images/graemlins/1zhelp.gif
  4. 82_k5
    Oct 3, 2003
    94
    Re: \"Red Hot\"
    anyone? I really need to know what's going on /forums/images/graemlins/frown.gif
  5. mxfireman
    mxfireman 1/2 ton status
    Dec 7, 2002
    2,480
    LHC, AZ
    Re: \"Red Hot\"
    Did this just start happening or did you do some motor work then it started happening?
  6. ColAdo82K5
    ColAdo82K5 1/2 ton status
    Feb 18, 2000
    789
    MO
    Re: \"Red Hot\"
    Running lean makes things hot...
  7. dyeager535
    26,975
    Re: \"Red Hot\"
    Pull off any of your emissions stuff?
    As was mentioned, running lean will cause this, and pulling off emissions equipment (particularly EGR) will cause the engine to run lean.
  8. fatboy
    fatboy 1/2 ton status
    Jul 1, 2003
    290
    Tennesse
    Re: \"Red Hot\"
    did you mess with the carb? or what was the last thing you did to the engine besides the manifolds? it needs more gas /forums/images/graemlins/burb.gif
  9. mxfireman
    Dec 7, 2002
    2,480
    LHC, AZ
    Re: \"Red Hot\"
    You know that Halloween is right around the corner I think they K5 would look sweet glowing RED under the hood. Not too ghoulish but you could work with it! /forums/images/graemlins/whistling.gif
  10. fr8train
    fr8train 1/2 ton status
    Aug 2, 2000
    1,712
    Maryland
    Re: \"Red Hot\"
    Double check the mufflers and see if they are on backwards. Were you doing any "hotrodding" since you upgraded your exhaust?
  11. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    Re: \"Red Hot\"
    Whats your engine temp? Sounds like a lean mixture. IIRC a rich mixture can have the same effect if the unburnt fuel is burning in the exhaust. Have any choke problems?
  12. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    Re: \"Red Hot\"
    Did you recently get new mufflers? What kind are they? A regular muffler on backwards will create excess pressure in the system and therefore heat. If its just a bottle type muffler or something with a simple design like that then thats probably not it.
  13. MOABDADC22
    MOABDADC22 1/2 ton status
    Jul 24, 2001
    1,348
    Cheyenne, Wy
    Re: \"Red Hot\"
    Last time I saw glowing red manifolds was when I smoked my Vortec....................................... /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif
  14. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    Re: \"Red Hot\"
    Lean or late. You are either running really lean due to a big vacuum leak (or a REALLY mis-jetted carb), or your timing is retarded.
  15. diesel4me
    Jul 24, 2003
    17,539
    923
    Massachussetts
    Re: \"Red Hot\"
    The exhaust manifolds in my 400 small block would turn a dull red after driving a few miles on the highway--I checked all the settings like timing,carb mixture,brakes dragging,etc--everything checked out ok--about a month later I had to replace the manfold because the crack it had from day one I brazed shut had spread--the "new"manifold felt about 5 lbs heavier--the other one was so corroded it was only about an eighth of an inch thick--too thin to keep it from turning red I guess--never did it again since!. /forums/images/graemlins/crazy.gif
  16. 85HeartBurb
    85HeartBurb 1/2 ton status
    Jan 10, 2002
    735
    Temecula, south
    Re: \"Red Hot\"
    I just went through this on my 88 tbi bbc the timeing was off and the cat was clogged!!!
  17. 82_k5
    Oct 3, 2003
    94
    Re: \"Red Hot\"
    The base gasket had a good sized leak, I fixed that and still no cigar. I think it may be the carb. I got a replacement at the junk yard but I'm not sure what it came off of because they guy took it off before I got there. I have only noticed glowing since then but it could have been happening before because I don't usuaully pop the hood in the dark right after driving it. The whole motor seems to be hot so could that also be related to mixture (to lean or rich)? I have no idea what temp it is because my temp. guage says it's only like 180 or less so that is clearly wrong. Thanks for all the advice.
  18. mxfireman
    Dec 7, 2002
    2,480
    LHC, AZ
    Re: \"Red Hot\"
    Sounds like the jetting on the carb you just put on.
  19. fatboy
    Jul 1, 2003
    290
    Tennesse
    Re: \"Red Hot\"
    temp in the combustion will not really affect water temp. If I recall right combustion temp is around 1100 deg I could be way wrong but I recall that.
    If you got a used qjet go buy a rebuild kit for it. Its not really that hard. Remove jets in you original carb and use those is what I would do. Good luck /forums/images/graemlins/burb.gif
  20. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    Re: \"Red Hot\"
    pull the plugs and see what they tell ya
