Red Line Heavy Weight Shock Proof Gear Oil
Discussion in 'The Garage' started by jjlaughner, Sep 15, 2004.
  1. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    http://www.jegs.com/cgi-bin/ncommerce3/ProductDisplay?prrfnbr=131019&prmenbr=361
    Shockproof Gear Oils: Recommended for heavily-loaded racing differentials and transmissions which see shockloading. Shock Proof contains a unique solid dispersion which cushions gear teeth to help prevent tooth breakage and allows the use of lower viscosities. Available as Super Light, Lightweight, and Heavy grades.
  2. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    I use that in all the rearend I build that use spools, lockers, or welded. It works great. I use the heavy stuff. It is equal to 75w250 oil /forums/images/graemlins/peace.gif
    Dan
  3. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    man 2 gallons would cost 64 dollars plus tax and shipping pretty expinsive /forums/images/graemlins/yikes.gif
  4. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i use that in my bike, great stuff. would use anything else. the only problem is trying to find it. plus its quite expensive
  5. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I use it too. It is awesome stuff. I run it in both my welded 14bff and also my locked 10 bolt front. It is great stuff and I recommend it highly.
    Harley
  6. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    How well does this stuff work in winter?!
    I mean, the 75 should mean it flows just as good as any other gear oil- but the 250- wow. Might be worth it for a tow rig.
  7. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    Do we have any redline dealers on here?
    I found a local place thats sells it for about $95 a case does that sound about right for the 75W250/75W - Heavy Duty? Thats $8.something a quart
  8. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    It did fine for me when I spent the winter in Colorado a few years back. The great stuff about that gear oil is once it coats the metal surface there is ALWAYS a film of gear oil on the metal.
    If you park you rig for a few days there will still be a gear oil film on the top of the gears that is above the fluid level.
    The funnel I use to fill my diffs with that stuff keeps a film of oil on it for months. It doesn't completely go away. Metal to metal contact is basically a thing of the past with that oil.
    It is definitly a thick gear oil but it flows fine once it warms up a little. Shouldn't be a problem with winter driving. The inside of the diff will still get warm enough to heat the oil up to a good flow thickness.
    Harley
