Red line on stock motor???
Discussion in 'The Garage' started by southernspeed, Mar 8, 2005.
  1. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    When I've run-in my rebuilt '90 TBI motor (all stock apart from flat top pistons), what's a 'safe' working RPM limit? I'm not talking about sustained screaming, but momentary, up thru the gears limit. Or maybe 2 or 3 seconds to get out of a hole, that sort of thing. Any ideas?.
  2. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    I would say 5K. I have ran my TBI 350 up to 5 k and a bit more with no problems. If your motor is stock you wont make much power over 4500. Thats where it starts to run out of cam and air.
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    5500 is stock max
    aways has been
    as general rule
    each engine can take only so much strain before kaboom, just like ppl one engine isnt identical to another, piston weights, rod weights, balance, etc,
    so forth,
    all factors
    if you really want to get technical,,
    good luck
  4. Philly87
    Philly87 1/2 ton status
    Jul 14, 2000
    465
    6
    El Paso, TX
    My stock TBI 350 in my 87 was around 5200 to 5500. I stuck it in 4-low and floored it to see where it shifted at. The one-two shift was right about 5200 so I'd say just above that would be redline.
    Phil
  5. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Just looking for a good 'ball park' figure instead of shifting at 4500 as I've always done in my trucks. Thanks!:grin:
  6. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    I know its lower than 60mph on the speedo, 4.10's, 33's, and 4LO......dont ask....
  7. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
  8. thezentree
    thezentree 3/4 ton status
    Sep 19, 2003
    7,198
    NC
    There's a reason I call him NASCAR.
  9. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    oh shut up, go fix your balljoint.
