RedLine Gear Oil, yes-no?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Burt4x4, Sep 4, 2001.
  1. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Hey gang, Its time to swap out my diff lube! My R&P rear has well over 500miles now and the front, well 4 wheelin trips sence swap so duno really?
    I was originaly told not to run RedLine gear oil on a new R&P set. So now that I'm 'broke in' I was thinking of switching to sythetic oil RedLine. what do you all think of this stuff?
    When doing a oil change do you all spray down the diff with brake cleaner to get the little metal flakes out?? I have a PowerLock, will brake cleaner do bad to the cluches n stuff?
    <a target="_blank" href=http://www.geocities.com/baja/5099>www.geocities.com/baja/5099</a>
  2. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    Run red line gear oil. That stuff works great. And do not use brake cleaner on the clutches, it will destroy them.
    86 Jimmy 4"lift 35"MTRs Other cars 69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
  3. Gold Rush
    Gold Rush 1/2 ton status
    1,498
    I never spray down or clean the inside other than wiping out with a rag. Go ahead with the Red Line oil, but will you need the additive for you rear? I didn't put any additive in mine and ran it with synthetic for about two years before it gave out. Things that make you go hhhhhhhmmmmmmmm.
    David
    <a target="_blank" href=http://www.extremeblazer.com>http://www.extremeblazer.com</a>
  4. RedDwarf
    RedDwarf 1/2 ton status
    May 9, 2001
    816
    North Central Florida
    Yes to synthetic. There's no reason not to.
    My own preference is Amsoil, though most of my diffs have Mobil1 Synth in them.
    Lift It, Lock It, LIVE IT!!!
