Redneck Fuel Injection
Discussion in 'The Garage' started by noahrob, Oct 15, 2006.
  1. noahrob
    noahrob 1/2 ton status Author
    Nov 26, 2005
    1,878
    Santa Barbara
    Has anybody here successfully installed their Q-jet in reverse? If so, how did it work and how did you rig the bracketry?
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Why would you want to do that ? Stall uphill instead of down ??
  3. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    There's a number of EB guys who have done exactly that. I don't know how it benefits, but there's those who claim that mounted backwards gives performance that is really close to EFI.
    B4 I did anything like that I'd be looking at extending the bowl vent as high up as the air cleaner will allow. After that I'd go floatless. After that I might think about turning it around, but at that point I'd just go TBI & be done with it.
  4. noahrob
    Nov 26, 2005
    1,878
    Santa Barbara
    The idea of turning the carb around is so that you STOP stalling going up hilll...when fuel requirements are high and the jets are starving. I have already extended the vent fuel as far as I can and TBI is pretty much out for the time being (unless omeone wants to help me dial it in) as I suspect getting it to work with my 383 will cost more and take longer than making a "z bar" to install the carb backwards...
    Who are the "EB guys"?
  5. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Aside from a real steep short downhill where my bumper touched ground , my quadrajet works great uphill . I call it Fool Injection .
  6. noahrob
    Nov 26, 2005
    1,878
    Santa Barbara
    Uphills are my issue, not down...I can do fine going uphill as long as I don't mash the accelarator, but on real lose terrain where I need HP and speed, the carb starves, especially on hills that are a few hundred yards in length...
  7. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    EB guys refers to early bronco.
  8. noahrob
    Nov 26, 2005
    1,878
    Santa Barbara
    Dang...that was demoralizing:crazy:
  9. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Riase the float just a bit , may help . And make sure the filters aren't restricted .
  10. sgarrison
    sgarrison 1/2 ton status
    Feb 4, 2005
    148
    Art's Bar and Grill Mt. Pleasant S.
    I think the E.B. guys mounted the Q Jets backwards due to a linkage issue.
  11. ntsqd
    Nov 28, 2002
    3,381
    So. CA
    Nope. On purpose.
  12. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    the qjet has the primary jets in the front of the carb, when going up a steep uphill, the gas uncovers the jets causeing it to stall. turning the carb around will put the jets in the back that will almost always covered in fuel when going uphill. they will be uncovered when going downhill, but you usually don't need any throttle and the motor will still run.
    when i rebuilt my old qjet, i raised the float level and never had a problem going up or down. i did have choke issues and took it off in favor of a reman carb. this carb has the float level set alot lower. it stalls out going up hill, i have even stalled it going down hill and couldn't restart (stuck in sand). the float level will do alot.
