Redneck Ram
Discussion in 'The Garage' started by DPI, Aug 25, 2002.
  1. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    Here is a pic of the new install. Everything is completely adjustable thanks to MOO.
    Notice the MOO D60 Axle Mount?
    And, here is the MOO Rock Rod Mount.
  2. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    if it is so redneck where is the duct tape , rags , hose clamps , pantyhose and [ EDITED TO ADD BAILING WIRE ] holding it together ?
    looks great ,send it to me so i can test it real good for
    ya /forums/images/icons/wink.gif
    looking closer the rod looks REALY small what dia is it ?
  3. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    Looks good, so how do you like the setup sp far? I am planning to do the redneck ram too. Did you use their rebuilt 2wd box or did you use the AGR box? Also, I like those MOO mounts.
  4. BOWTIE
    BOWTIE 1/2 ton status
    Dec 28, 2000
    2,018
    Outside with the sawzall.
    that set up looks sweet.
    are the MOO brackets available or does he make as needed??
  5. BigOrange90Jimmy
    BigOrange90Jimmy 1/2 ton status Premium Member
    May 24, 2002
    2,923
    Wilmington, NC
    you forgot bailing wire
  6. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    Thanks.
    I love the setup so far. It seems to do a better job than my two steering stabalizers did, plus with the 1.5" diameter ram, it turns as fast as before and I did no modifications to my factory pump. I used the rebuilt box from WTO. I did add a power steering cooler.
  7. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    He makes the Rock Rod (tie rod) mount as needed, but had the axle mount in stock. The axle mount is the same mount he uses for the 14 bolt axle guard, the axle tube is 3" in diameter. He sent them to me without the tabs so I could weld on my own. He will weld the tabs if needed.
  8. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    I hide the duct tape, and bailing wire good huh?
    Are you talking about the ram rod? I think it's 1/2" diameter. It may look small next to my 1.5" diameter Rock Rod. I think he also has one with a 5/8" diameter rod. But it has 1.875" diameter ram. He basically said that would negatively effect the street manners. ie; slower steering response, the need to modify the pump, bigger ps fluid reservoir.
  9. greywolf
    greywolf 1/2 ton status
    Oct 18, 2001
    1,606
    ST.PAUL TX USA
    is that a 2 wheel drive box or 4wd box?
  10. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    Man, that truck of your's is too pretty /forums/images/icons/laugh.gif. You sure you want to take that to Disney?? Lookin' good.
    John
  11. BigOrange90Jimmy
    May 24, 2002
    2,923
    Wilmington, NC
    that's hilarious, but you didn't have to do all that /forums/images/icons/wink.gif
    it does work though, along with many hose clamps.
  12. WakeBoard&4X4er
    WakeBoard&4X4er 1/2 ton status
    Jun 29, 2000
    2,325
    Lee's Summit, Mo
    some of us can make it in diz with no body damage!
    opps. kiss of death!! i might not go in the rock garden this time!!
    haha
  13. WakeBoard&4X4er
    Jun 29, 2000
    2,325
    Lee's Summit, Mo
    MOO is da poo ($#!T)
  14. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    It is a two wheel drive box.
  15. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    Hey now. I've been there once with no damage. Why do you think I have all the body armor? /forums/images/icons/grin.gif
  16. SkulzNBonz
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    Body damage builds character /forums/images/icons/grin.gif That, and if you do it right, you walk away with free stuff too!!
    John
  17. BIGJ
    BIGJ 1/2 ton status Author
    896
    Central Arkansas
    Here's some slight body damage for ya [​IMG]
    I got my passenger window crushed for "free" too /forums/images/icons/smile.gif Gotta love the free stuff....
    BIGJ
  18. SkulzNBonz
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    Oh man, that's startin' to look like my passenger door. Luckily my dents pulled most of the way out with a plunger /forums/images/icons/grin.gif. No broken door glass, though. You must've been havin' fun!
    John
  19. BIGJ
    896
    Central Arkansas
    Yep, havin' lots of fun, trying to get the blazer to fit on a "jeep" trail /forums/images/icons/smile.gif It was a 4/5 trail, and I expected to get some damage, but not the whole door /forums/images/icons/frown.gif I'm going to pull the worst of it out, and leave the rest. Next time I'm just taking the doors off.
    BIGJ
  20. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    Man, you needed some sliders! I can make you a pair /forums/images/icons/grin.gif JK!
