Redneck Rev-Up (Carb Question)/ Cam shaft replacement
Discussion in 'The Garage' started by 78 k5, Apr 18, 2005.
  1. 78 k5
    78 k5 1/2 ton status
    Jul 8, 2004
    261
    Auburn, AL or ATL, Ga
    I fell victim to peer preasure at a rodeo this weekend and reved my engine beyond belief. I blew some oil out but I don't think its a big deal... The truck started a small clicking shortly after the event and became really loud on the way home. After towing it back to the house I figured I had a rod trying to come through the valve cover but after removing both valve covers I found that both sides were fine. I cranked the truck and removed the air cleaner and found that the knocking was coming from the carb???WTF It is an Edlebrock 650 (I think) What did I do? Anyone had this problem before?
  2. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,995
    133
    If you didn't break a valve spring or rocker arm (you could see this with the valve cover off), it is a bearing knock. Pretty common from overrevving (stock oil pump can't keep up with really high RPM's). The noise you think is coming from the carb is probably coming from much lower in the engine (the harmonics of steel can make finding a noise deceiving). You are probably in for at least a new set of bearings all the way through.
  3. stevewix
    stevewix Registered Member
    Dec 2, 2004
    83
    it's valvetrain...
    when a cam goes flat it exhibits this 'popping sound' through the carb under any kind of throttle. except idle in most cases.
  4. M-1028
    M-1028 1/2 ton status
    Feb 2, 2005
    217
    Sealy Tx
    My old jeep did that, it ended up being a flat cam. When you round off an exhaust lobe the exhaust gasses can't go any were but through the intake valve and up through the carb.
  5. 78 k5
    Jul 8, 2004
    261
    So what are we talking about here...big problem or not? I'm pretty savy around axles and suspension, but I'm pretty much a newb when it comes to engine work. I will have a mechanic friend that will probably be doing the work for me, how much damage am I looking at $$$$$$$$$$ a couple hundred or big money??
  6. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    You're going to need to pull the valve covers and check for valves that are not moving. This should tell if you've got a lobe or two rounded on the cam. This is the easy thing to fix - change the cam (and maybe lifters while your there). If its bearings, its going to require a little more work, but you can probably do that with the engine in the truck.
  7. 1977k5
    May 26, 2003
    9,995
    133
    It definitely could be that cam as well (these guys are probably right), but it is a result of starving the engine of oil from over-revving it.
  8. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    Are you sure its from the carb? Could you have blow out a header gasket? Just some wishful thinking for you. :xmas:
  9. 78 k5
    Jul 8, 2004
    261
    Anyone have a jegs or AutoZone part# for a replacement cam for my sb350??? Any writeups or pictures of a cam replacement to help me along my way? Thanks in advance
  10. trailblazer86
    trailblazer86 1/2 ton status
    May 16, 2004
    112
    North Shore of Lake Ontario
    If you have the rocker covers off check to see if you have any loose rockers.
    If you are luck you may have just bent a push rod or bent a rocker arm.
    The sound of a knock can also give you some idea. The sound of a connecting rod is different than a wrist pin or a valve train knock.
    Sometime high revs in an older engine can also break the skirts off the pistons. This of course will also sound different than the others.
    If the valve train seems ok, pull the oil pan. It is amazing how much aluminum can be in the bottom of the pan or in the oil pick up and that poor old engine may still get you home.
