Redrilling 9" to 6 lug
Discussion in 'The Garage' started by b454rat, May 5, 2007.
  1. b454rat
    b454rat 1/2 ton status Premium Member
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    Quicky, is there enough room/material on a Ford 9" to redrill to GM 6x5.5??
  2. jtrux
    jtrux 1/2 ton status
    Jan 14, 2007
    185
    San Antonio, TX
    I hope someone has an answer, i'm wondering the same damn thing.
  3. b454rat
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    I was looking into this when I had intentions of SAS'n my S-10, have the 9" rear, but wanted 6 lug, someone said that was, but want to confirm. Don't want to spend $300 on a set of axles when stock will do.
  4. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    i believe they make wheel adapters for ford 5 lug to chevy 6 lug
  5. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    if not I am sure someone like Moser or the like would make you a set of axles with the 6 lug pattern. They really don't charge that much more for that stuff. Then you have nice axles too. I think there is probably enough room, but that some of the existing holes may interfere with the drilling. I know you can drill to a GM 5 lug pattern, Dad had a 9" in one of his race cars that just had redrilled stock axles.
  6. b454rat
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    Maybe for the he!! of it I will call an axle company and see what the cheapest route is. Going with the adaptors isn't a bad idea, will also widen the track to sorta match the front. I bought axles for the 9" I had in my Malibu, and they were $300 IIRC. But they were 31 spline Mosers, good stuff but pricey for what I need. I might run the stock pattern, the old man has a nice set of 15x10s that are pratically new, pretty sweet lookin......hmm see what happens....
  7. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    There should be plenty of room to re-drill to 6 lug but might need to have a hole plugged before doing so. The cost to have them re-drilled might be about half of a quality pair of axles already with the bolt pattern you want though.
  8. b454rat
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    I had the stock axles resplined before I got Mosers, and only cost me $50 or so, plus studs. Think it was $100 all together. Had the longer racing studs too, so more expensive than stockers....
  9. NEK5
    NEK5 3/4 ton status Premium Member
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    what ratio came in the ford 9" rear ends?
  10. b454rat
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    Anything from 2.29-ish up to 4.56s guessing factory, but can go to 7.17s I think. I only want 3.50-3.70, maybe 4.10s. Found a set of 3.70 in a yard here, just have to get a set of 3.73 for an HP. But, there are two axles there already with 3.55, one is already 5 lug and leave sprung. One of them there ext cab fronts, other is a 3/4 ton.
  11. RedBrute
    RedBrute 1/2 ton status
    Sep 22, 2002
    346
    Southern tier New York
    Unless I'm mistaken, ford truck bolt pattern is 5x5.5. That means you could drop a six lug chevy rim on and one lug stud would line up... there may be overlap on a few holes but I think it's do-able.
  12. b454rat
    Jan 21, 2003
    3,009
    7
    Binghamton NY
  13. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Most Ford 9" flanges have an extra large hole to access the retainer nuts. Might get in the way of the new pattern.
    I have 2 friends that had their 9" shafts welded and redrilled for ~$100/pair.
  14. b454rat
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    For some reason I thought you couldn't weld on the flange?? Heating it would take the temper out of it?? I can probly get that done next to nothing.....I'll have to check. Thanks!!!!
