redrilling axle shafts 6-8-lug?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 90K5, Sep 9, 2001.
  1. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Can a machine shop fill i nthe oles on an axleshaft and redrill them to 6 lug instead of 8? Need to know for 14bolt SF rear...TIA
    90K5
  2. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>I've seen this done, so yes it is possible.</font color=blue>
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I can see someone doing it--but I wouldn't. I'd go to the junkyard and locate some 6 lug shafts first, definitely.
    Tim
  4. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    problem is, 6 lug shafts are newer, and a lot harder to find...
    90K5
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Moser will make up a brand spanking new set of axle shafts for around $215. JY's around here want $150 for a set of old used stock ones! [​IMG] Check 'em out at <a target="_blank" href=http://www.moserengineering.com>http://www.moserengineering.com</a>
  6. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>The 6 lug SF housings are wider than the 8 lug 83-87/91 housings are so the shafts will have to be cut and re-splined I think. Its easier to re-drill 8 lug shafts.</font color=blue>
  7. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,084
    486
    Grand Rapids area
    I'm not sure about this, but I think it is possible to get an 8-lug to 6-lug wheel adapter for the SF. It should add 1.5-2 inches of track witdth to each side, making the rear tires sit pretty close to the same width as the front. I know that it can't be done for the FF 14B because of the huge hub (at least without adding a foot of track width to each side).
    try <a target="_blank" href=http://www.advanceadapters.com>www.advanceadapters.com</a> or somebody like that.
    <font color=green>"It is generally not adviseable to eject directly over the area you just bombed"</font color=green>
  8. Donovan
    Donovan 1/2 ton status
    524
    Arvada, CO
    I did a 14 FF 6 lug here is the picture. <a target="_blank" href=http://www.rustbucket.rockcrawler.com/photo.html>http://www.rustbucket.rockcrawler.com/photo.html</a>
    Donovan
    Nitro Fumes makes me Horrrrny
  9. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    14 SF, not 14 FF
    And as for the axles being harder to find, I disagree. Junkyards around here don't keep old stuff anymore. The new stuff is easy to find.
    Tim
