redrilling perches to move axle forward on d60
Discussion in 'The Garage' started by muddybuddy, Feb 6, 2007.
  1. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    im going to be running 52's up front, and want to push the axle forward another 1" or so from the 2-2.5" the 52's net. i dont want to run a zero-rate. how much farther back can you drill the hole on the pass side and still have it safe?
  2. bigbluesuburban
    bigbluesuburban 1/2 ton status
    Feb 8, 2006
    1,362
    Constant State of Perpetual Anger
    Coming from the structural steel industry here is a rule of thumb.
    Your hole should be at least one diameter away from the edge of the plate. This means that if you have 1/2" dia pin, the distance from the edge of the plate to the edge of the hole should be no less that 1/2". Also this applies to a drilled or machined hole, not a flame cut hole.
    This is not carved in stone, but like I said it's a good rule of thumb.
  3. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Good info there.
  4. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    anybody got access to a d60 right now that could measure? im away from my truck so i dont have access to my 60 to see how far forward it will end up net'ing
  5. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,994
    130
    I'll be doing the same thing, post up when you figure it out.
  6. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    has nobody else done this? i thought that more people had tried it
  7. muddermilitia
    muddermilitia ThatTrazerGuy GMOTM Winner
    Nov 10, 2005
    5,742
    76
    NE Illinois
    sorry dude, im wondering the same thing
  8. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    You are probably tired of hearing from me on this stuff, but I moved my axle forward 1" by drilling the D60 perches. You also have to drill the top plates for the center pin clearance.
    This is the only pic I could find here at work that kind shows location of the front axle. I trimmed more of the front fenders due to tire to fender contact under flex. I posted those pics in your fender trimming post.:doah:
  9. mrk5
    Apr 20, 2004
    12,335
    1,044
    Northern Colorado
    Sounds like as good a logic as any. :waytogo:
  10. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    you could always drill an new hole through your spring pack.
  11. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    dpi, thanks for the info. so after you drilled the hole 1" back there was still plenty of room to keep its strength?
  12. mrk5
    Apr 20, 2004
    12,335
    1,044
    Northern Colorado
    You could always get a new perch from DIY4x or Ruffstuff.
  13. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    I don't think that would help any considering the one side perch is cast right into the housing............
  14. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    i thought about that but how will that work with the pass side perch on the 60?
  15. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    Yeah, there was plenty of room left. IRCC the perchases are 5" long. So redrilling an inch from center is no problem.
  16. mrk5
    Apr 20, 2004
    12,335
    1,044
    Northern Colorado
    I was working from the assumption there is more room to play with on the passenger side cast pad. The driver's side has that extreme radius at the ends.
  17. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    Grind it till its round and weld on a perch. ....Thats what a couple guys have done at teraflex
  18. jekbrown
    May 19, 2001
    45,030
    366
    Vancouver, WA, USA
    did it on my 60, as I wrote in the 52" spring swap tech article. I drilled exactly 1" behind the stock holes. I don't know exactly how far from the edge that left me (more than 9/16" though)... but just looking at the perch I wasn't willing to move the center any more than that. Something about drilling any closer to the edge just tweaked my shady-tree engineer spidey sense.
    j
  19. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    hmm, maybe i could get some "lift" perches as well to keep down the arch of the 52's so i can still get ~6-7" lift
  20. 1977k5
    May 26, 2003
    9,994
    130
    Sounds like a bad idea to me. Others seem to have had troubles with breaking springs that way.
