Reese hitch w/ ORD flip
Discussion in 'OffRoad Design' started by RLBstein, Apr 26, 2001.
  1. RLBstein
    RLBstein 1/2 ton status
    Jul 2, 2000
    179
    Pensacola, FL
    Has anyone else had a problem installing a Reese type hitch with a shackle flip. It seems the new hardware covers the hole where my hitch once bolted to. I don't really want to drill a hole in my new shackle flip and add a spacer on the rear one to level it out. Does anyone have a solution besides not putting a hitch on.
    85 Blazer on an 82 chassis, 6.2L Diesel, ORD flip, 35's with no cutting on a 4" lift.
  2. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    I have that type of hitch and had no problems with the install.
  3. yeild2me
    yeild2me 1/2 ton status
    Jan 7, 2001
    1,309
    fayetteville, nc
    had the same problem.....only thing i could think of was to notch the bottom part of the bracket to make room for the hitch...it worked great, but i havent put the bolts back through the hitch holes....the nuts for my hitch are the "rectangle" ones that dont need a wrench to tighten...they dont fit, so i need to get new hardware....i scratched my head for about an hour when this dillema popped up...
    BTW dont laugh at my signature!!!!!
    AIRBORNE!!
  4. RLBstein
    Jul 2, 2000
    179
    Pensacola, FL
    I had to laugh at your signature a little, I work on the c-130's you jump from.
  5. extremeblazer
    extremeblazer 1/2 ton status
    Dec 5, 2000
    129
    Albany NY
    I had the same problem with my shackle flip and hitch. I called ORD last year and asked if I could notch the bracket. They said it should be ok because the notch was just in the last 1/2 inch of the bracket and they have plenty of beef. I notched and installed the brackets and hitch about seven months ago and have had no problems with the shacle flip brackets or towing.
