refrigerator and below freezing temps ?
Discussion in 'The Lounge' started by R72K5, Dec 24, 2004.
  1. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    will a normal stand up refrigerator be damaged in any way if its left in below freezing temps all winter ? matter if is frost free or not ? how about a 1950's style dome top one ?
    '80's square one ?
    got both out there its 10 degrees out and gonna be below zero tonight again and well all winter every night basically
    thanks
  2. unclematty
    unclematty 1/2 ton status
    Jan 24, 2003
    3,164
    SLC UT
    shouldn't hurt anything, maybe the moisture condensation that comes with temperature change might be the only problem!
  3. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Technician just said don't run it when its outside that cold , could snap something in the compressor from the oil bring thick and not flowing well . I think it would cycle off if its cold and not run often :xmas::xmas:
  4. paulmoon
    paulmoon 1/2 ton status
    Feb 11, 2004
    211
    Reno, NV
    I have heard that running them in the cold is bad for them. I've run two different ones in my garage for years without problems yet. One older and newer one. Maybe just lucky so far. Our temps here vary between -20 and 30's during the winter. Mostly 20's on the average. I guess I should probaby just unplug it for the winter.
  5. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    why would it run at all? In fact everything in it will eventually freeze if the temp outside stays below freezing.
