Regear on my front Dana 60 to 4.56... can I get thick gears?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by K5thatShmobs, Feb 10, 2003.
  1. K5thatShmobs
    K5thatShmobs 1/2 ton status
    Sep 27, 2001
    353
    San Luis Obispo, CA
    Do I have to get a new carrier for my front 60 if I want to go to a 4.56 ratio, or is there somewhere I could get thick gears?
  2. Langosta39
    Langosta39 1/2 ton status
    Nov 8, 2002
    156
    Moscow, Idaho
    Randy's Ring and Pinion has thick gears
    andy
  3. K5thatShmobs
    Sep 27, 2001
    353
    San Luis Obispo, CA
    I called Drivetrain Direct, Randy's R&P, and 4WP, and none knew of a thick 4.56 for the Dana 60 smaller carrier. They all said I would need a new carrier. Is there still any hope?
  4. Swanson52
    Swanson52 1/2 ton status
    Mar 27, 2002
    2,586
    Centennial, CO
    I don't list one available from any of the following; Precision Gear, Richmond, Dana-Spicer, or Genuine Gear. You might be sh!t outta luck with this one. /forums/images/graemlins/tongue.gif
  5. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    My understanding is no, you have to get the new carrier.
    -- Mike
  6. Langosta39
    Nov 8, 2002
    156
    Moscow, Idaho
    Well maybe I read the chart wrong:
    http://www.randysringandpinion.com/dana-spicer.shtml
    But it seems to say they have it. I called randy's one day and talked to someone who said they dont have thick 4.56s for a 14bolt, but the next day I talked to a guy who said they did. couldnt hurt to try again.
    andy
  7. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    I've done that samething too...called and they have what Im looking for, then call back and no one has a clue...get the part numbers and the guys name... /forums/images/graemlins/deal.gif
  8. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    I did some research on this a few months ago and couldn't find any company or shop that knew of any "thick" gear sets for the Dana 60. I have talked to a few people who say that a spacer ring work okay on the 60 because the centering ring on the carrier is deep enough to center both a spacer and gear.
  9. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I could never find any for the front. The rear you can though (14 bolt). I got my carrier from Boyce for $100.
  10. 6.2Blazer
    Feb 24, 2000
    4,675
    26
    Ohio
    There are 4.56 open carriers for sale on e-bay all the time for pretty cheap.
  11. ken
    ken 1/2 ton status
    1,244
    Anaheim, CA
    Just run a spacer till you can afford to upgrade to some type of locking diff.
  12. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    what gears do you have now?
    when are you doing the regear?
    are you certain on the 4.56 or would 4.88s work as well?
