regearing a 10 bolt
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by jacksprat1599, Sep 10, 2004.
  1. jacksprat1599
    jacksprat1599 Registered Member
    Dec 13, 2003
    99
    Austin Tx
    I have an 89 suburban that I would like to put 35s on.Through reading the posts here it sounds like I want to go with 4.88's.My plan is to find a junkyard 10 bolt from an 89 thru 91 truck so I can stay 30 spline with the axles and do the gears myself.I have never done gears before so thats why I want to try setting up new gears on an axle that I don't need back in service right away.Does anyone no of a good book or manual that covers gear instalation,preferably on GM axles? What brand of gears do you guys recommend? Am I getting in over my head on this one?Any help would be greatly appreiciated,I have learned alot from readig all you fellas posts.I know some guys are going to say go 14 bolt, but I really don't need it.My truck is 98% pavement and my offroading is mainly just camping but the tires would be nice to keep my Burbs butt out of the dirt.Besides do you really need a reason to want a lift and bigger tires?
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Re: re geraring a 10 bolt
    You're getting in over your head. I would attempt my own gears, but I wouldn't suggest it to a person who isn't really into this stuff.
  3. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I have become a 1/2 ton guy , and would reccomend that for a Blazer on 35's , but in your case with a Heavy Sub , I would get a 14bsf or 14bff .
    The only reason I would say this is because my buddies 10 bolt 30 spline axle , on 31's , bent off road and soon wore his bearings out .
    I would say do it if you have a K5 and run 35's but not in a Sub /forums/images/graemlins/k5.gif /forums/images/graemlins/k5.gif
  4. smprider112
    smprider112 1/2 ton status
    May 1, 2004
    624
    Beaverton,Oregon
    ya, I know alot of guys who will do EVERYTHING themselves on there truck....from fabing up spring hangers and bed mounted shock hoops and everything else you could imagine...but they WILL NOT touch there gears!! Proper gear setup is critical in the life of yer differential!! I'd say either find someone who knows how or get it done by a shop....about the farthest I would go...is to just do the front end since it only gets used while in 4x4 /forums/images/graemlins/thumb.gif
  5. botboy
    botboy 1/2 ton status
    Aug 11, 2004
    225
    Delano, MN, USA
    Hope this helps. I've rebuilt two and haven't had any problems before I read this article...so it isn't that hard, but then again I don't beat the baby bejesus out of my trucks either...
    http://www.fullsizechevy.com/fscu/axletech/
  6. jacksprat1599
    Dec 13, 2003
    99
    Austin Tx
    Thanks for that article!I don"t feel so intimidated anymore.I still would like to know who you guys would buy a gear and install kit from and is 4.88 right for a suburban with overdrive and 35's?
  7. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Btw since you live in austin come check out www.austink5.com its a local forum that is here is austin. /forums/images/graemlins/thumb.gif
  8. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    I wouldn't go 4.88.. The lowest I would go is 4.56. The pinion starts getting to small. and you are carring a lot more wait in the burb.. My first K5 I did 4.56 in the 10 bolts.. But I just went with 33's it was a nice setup..
  9. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I wouldn't go 4.56 with overdrive in a rig with 35s. Not enough gear.
  10. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    It's better then 3.73 you can't have everything if you want to stay with the 10 bolts.. The pinion is to small. for the wieght of a burb.. and towing if he is going to.. and you telling him..
    [/ QUOTE ] You don't now what he is capabale of.. I would not do a gear install.. I have seen a few done.. But I am the first to admit I am not a mech.. But I have seen plenty of other people do it with no problems..If he reads up on it he could probably do it..
  11. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    i'll second that. i built up my 10bolts with 4.56 gears and 33's and i think its just right. for a heavy sub i would go 4.88, but not in a 10b. if your stuck on doing a 10b stay with 4.56. i just dont trust those small pinions.
    even if you only drive on the street i still think the 10b is a bad idea. i dont know why they even put them under subs. just loading all your camping gear and passengers probly would overload it.
    by the way if you regear the rear youll have to do the front, unless you never want to use 4wd again. so to do it like you want to and get a junkyard axle, you'd have to get a front axle as well.
  12. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    This is one of those things, if you have to ask, you probably shouldn't do it.
    Sure he can attempt it. I'll be doing mine sometime soon. /forums/images/graemlins/thumb.gif
    Anybody can do it. It can't be any harder than building an engine. Maybe more frustrating, but not any more difficult.
  13. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    Then Tim. You shouldn't do it either.. Cuse your going to ask somebody a quistion on it..
  14. jacksprat1599
    Dec 13, 2003
    99
    Austin Tx
    Thanks for the link
  15. jacksprat1599
    Dec 13, 2003
    99
    Austin Tx
    you are right about the front axle I thought I would start with the rear just to see if I am capable enough to get the job done.
  16. jacksprat1599
    Dec 13, 2003
    99
    Austin Tx
    It seems that the majority believes the 10 bolt to be to weak for the light uses that I have in mind.So, what does a used or junkyard 14 bolt go for?Let me know what some of you guys have paid to have a pro do your gears.
  17. Jonny-K5
    May 27, 2003
    1,654
    SoCal
    expect to pay between 50 and 250 for a used 14b.
    look in your local recylcer/trader magazine for better deals than the junkyards.if you get one out of a 3/4 ton, it'll have the spring pads in the right location. but 1 tons will have larger rear brakes, i think.
    regearing an axle usually costs between 3 to 5 hundred for labor depending on the shop. 4wp qouted me 425 for the rear and 475 for the front . parts(gears and bearings,install kit)figure on 2-4 hundred .
    i did both my axles with the help of a seasoned pro mechanic. i wouldnt have attempted it by myself. i think the rear is more critical than the front causs your always turning that one, and going 75 mph on the freeway you want those gears set up perfect.
    if you wanted to try it, i'd do a front axle before you try doing a rear. just causs its less critical.
    maybe if you find a cool axle guy he'll let you watch him do the rear. then with that knowledge you could attempt the front.
  18. ugly_blazer
    ugly_blazer 1/2 ton status
    Apr 12, 2004
    1,214
    Nice article, it makes it look easy.
    In the article after everything was set and he was installing the differential for the final time, he says
    Tighten down the bearing caps to 60 ft pounds using a 5/8. Socket. You could recheck backlash again, but everything should be so tight that it is probably impossible.
    Does this mean that the pinion will be very hard to turn?
  19. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    You don't turn the pinion when you check backlash. You simply put the dial indicator on the ring gear and, "rock" it in the housing to find out how much play there is between ring and pinion.
  20. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Just remember that gears can be a pretty costly mistake.
