regearing axle
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by CenTxk5blazer, Apr 22, 2003.
  1. CenTxk5blazer
    CenTxk5blazer Registered Member
    Oct 19, 2002
    90
    Fort Worth, Texas
    I've never regeared an axle before, how hard is it?
  2. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    Dropping new gears in your axle is relatively easy aside from getting the larger pinion nuts free. Setting the gearing up with the right backlash and pattern is rather difficult and not very friendly to error in the long run. A lot of trail only rigs get away with shade tree installs, a daily driver is best left to a profesional with the right tools and know how to set it up right, the first time. Getting an axle regeared can run you anywhere from $400 to $800 at a shop.
  3. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Theres some special tools required. It also depends on what kind of axle, some are harder than others.
  4. TxK5Blazer
    TxK5Blazer 1/2 ton status
    Aug 13, 2000
    593
    Floresville, Tx
    what axles do you have and what gears do you have ? Also what gears do you want to go to?....Jason /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif /forums/images/graemlins/pimp1.gif
  5. CenTxk5blazer
    Oct 19, 2002
    90
    Fort Worth, Texas
    right now I have the stock 10's, I don't know the ratio yet, and am running 33's now and will eventually go to 35's. I was thinking of going to a 4.10 or 4.56 ratio.
