Regearing-swapping just the pinion?
Discussion in 'The Garage' started by lochenjons, Apr 8, 2007.
  1. lochenjons
    lochenjons 1/2 ton status
    Sep 13, 2006
    682
    Santa Cruz, CA
    This probably doesnt work... but my autoshop teach counted the gears in my 12b to see what ratio it was because I had to regear the front to be the same and it turned out to be 4.56. Well I popped the cover today to get out a bolt I had broken in it and just for the hell of it counted everything. 41 to 10...thats not right i thought...thats 4.10. So I counted again...and again...and again...still got 4.10. But now my front is 4.56 :doah:. So could I just swap in a pinion with 9 teeth?
  2. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,992
    130
    Nope, gearsets are matched.
  3. DEMON44
    DEMON44 Low-Tech Redneck
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    what he said.
  4. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    The numbers are also stamped on the edge of the ring gear... just for if you don't like counting.
  5. lochenjons
    Sep 13, 2006
    682
    Santa Cruz, CA
    Yeah I saw them when me and my teacher were looking at them and it said 4.10 somewhere in there. And he was like oh well lets count anyway to make sure :doah:
  6. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    Different ratios are "matched" in the fact that the pinion gear has to be a different diameter to have a different number of teeth...the gear teeth are the same size so obviously one with more teeth will be larger in diameter than one with less teeth. The ring gears are then thinner or thicker so they mate up with the pinion gears properly.
  7. lochenjons
    Sep 13, 2006
    682
    Santa Cruz, CA
    Is having 4.10 in the rear and 4.56 up front close enough that it wont be too much of a problem untill i get another axle or regear the one i have?
  8. dremu
    Feb 27, 2000
    15,954
    445
    East of San Francisco
    Don't run it in 4WD, no.
    4.09:1 and 4.10:1 are close enough, but 4.10:1 and 4.56:1 are ~11% difference, which is like the difference between 33" and 37" tires :eek:
    -- A
  9. vortec
    vortec 1/2 ton status
    Jul 22, 2004
    1,472
    fort worth, texas
    NO. i would never run two different ratios, even offroad. in loose mud and stuff, you could get away with it, but it's just not wise. in your case, i just get this mental picture of the faster-spinning rear tires trying to run up and hit the slower front ones, resulting in an upside down k5 taco. but, since i'm sure neither you nor your truck is a cartoon that probably won't happen, exactly.
    of course, there's always putting larger tires on the front to bring the final ratios near equal. that would look really cool. :haha:
    just do it right and avoid the headache. my $.02
  10. lochenjons
    Sep 13, 2006
    682
    Santa Cruz, CA
    Lame, I figured. Well that sucks, so much for my hollister hills trip in a couple days. Anyone got a 4.56 10/12b?
  11. Speedo
    Speedo 1/2 ton status Premium Member
    Oct 31, 2005
    474
    27
    Talkeetna, Alaska
    There's more to it than that, even though you might have two gear sets for the same model axle and the same ratio you cannot mix up the gears. Gears are lapped as a pair and need to stay as a matched set. Dana usually stamps a three digit number on the ring gear and the matched pinion will have the same number etched on the end of the pinion, this number is called the pinion mate number.
    Gus
  12. BlazerBud
    BlazerBud 1/2 ton status
    Jun 14, 2006
    473
    Chattanooga
    This was your teacher that made the mistake? No, it was you who made the mistake! Lesson learned. Been there done that.
  13. lochenjons
    Sep 13, 2006
    682
    Santa Cruz, CA
    Normally I'd agree, and dont get me wrong here I'm not putting my teacher down at all, I definately respect my teach and he has crazy skills, but I wasnt the one that counted it, I probably should have too but oh well :o. I just turned the wheel. It doesnt matter awhole lot since I'd rather have 4.56 anyway, now I just gotta find an axle.
