regroovable tires
Discussion in 'The Garage' started by K5Redneck33, Feb 9, 2003.
  1. K5Redneck33
    K5Redneck33 Registered Member
    Aug 31, 2002
    47
    INDIANA
    is it possible to re-groove 15-38-15 hawg radials? i got a set of used ones and there low on treads /forums/images/graemlins/k5.gif <font color="red"> </font color>
  2. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Do you mean re-tread?
    There are companies out there that specializing in re-treading tires. They usually do tractor trailer tires, but I've seen a mud tire pattern before. There used to be an add in the older 4x4 mags that was for a re-treading company. I forgot the name, but a search on google may find them. I don't know if they will do a tire that size. /forums/images/graemlins/confused.gif Also, you won't get the Ground Hawg pattern you want...they use whatever they have. And, if I remember correctly, the price for a re-treaded tire didn't jump out at me as being a good deal...but it's worth looking into for a 38.
  3. 77fixer
    77fixer 1/2 ton status
    Nov 22, 2001
    464
    Meridian, ID 83646
    I don't think there is enough rubber before the cords to regroove like you're thinking. Now, I had a set of Buckshot Mudders that had wear bars that connected the center lugs at 1/2 tread and created a zig-zag pattern. I always thought about cutting those out to open up the pattern again.
    Brett /forums/images/graemlins/burb.gif /forums/images/graemlins/k5.gif
