regulator on holley blue electric fuel pump
Discussion in 'The Garage' started by garlicbreath, Apr 28, 2006.
  1. garlicbreath
    garlicbreath 1/2 ton status
    May 17, 2003
    1,136
    Denver
    Does anyone know if the regulator that goes with the holley blue 14PSI fuel pumps need a return line? How do they regulate the pressure?
  2. Diesel Dan
    Diesel Dan 1/2 ton status
    Feb 27, 2002
    798
    Warren, Ohio
    From what I remember it is only a dual port regulator, one in and one out. It internally regulates without a bypass port. On the project I'm working on we are ordering the Holley 12-803BP regulator. It is a 3 port with return and are going to regulate the pressure after the carb.
  3. crazyhole812
    crazyhole812 1/2 ton status
    Jul 6, 2005
    228
    missouri
    i run a holley blue on my truck. but the old guy told me to throw away that regulator that came with it. i have a BG regulator, after the carb as well. this guy has raced for years so i guess he knows what he's talking about
  4. garlicbreath
    May 17, 2003
    1,136
    Denver
    What do you mean a regulator after the carb?
  5. nvrenuf
    Jan 7, 2002
    13,079
    247
    Mobile, Al.
    +1... This is what I had on my old K10 and worked flawlessly.
    The part is a BG "bypass" regulator. :wink1:
  6. nvrenuf
    Jan 7, 2002
    13,079
    247
    Mobile, Al.
  7. crazyhole812
    Jul 6, 2005
    228
    missouri
    the reg goes on the out flow side of the carb supply line (behind the carb by the firewall)
