Reinstalling Front Axleshafts
Discussion in 'The Garage' started by JoeAngelicchio, Aug 19, 2004.
  1. JoeAngelicchio
    JoeAngelicchio 1/2 ton status
    Feb 18, 2000
    628
    South Central Ontario, Canada
    I'm doing my front axleshaft u-joints and when pulling the shafts out, along came a ton of grit /forums/images/graemlins/yikes.gif. What's the trick to reinstall them without pushing all that crap back in and getting it on the shaft? Vacuum it out?? Any other methods?? /forums/images/graemlins/dunno.gif
    Joe
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    I made a tool to scrape out the axle tubes, then once everything was loosened up I jammed in the hose of a shop vac to get the loose stuff out. Just make sure you yank the cover before vacuuming inside of a tube, or else you'll suck grit from the opposite side right into the diff. /forums/images/graemlins/yikes.gif
  3. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    I use a shop vac, or pull the carrier and use a garden hose /forums/images/graemlins/thumb.gif
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Are you nuts?
    DON'T EVER OFFER TO HELP ME WORK ON MY TRUCK!
    A garden hose, inside a gearcase?
    Maybe if it's torn down for rebuild or something, but otherwise, BAD IDEA!!!!!
  5. readymix
    May 30, 2004
    6,706
    26
    Note that i said "Pull the carrier and use a garden hose"
    I did it when i installed my detroit in the D60. You just have to keep the water slow or the dirt could end up around the pinoin. But if done right you can stick the hose in the pumpkin end of the tube and wash out almost all of the dirt.
  6. JoeAngelicchio
    Feb 18, 2000
    628
    That's what I did too. Used a 1 1/2" pulley on the end of a 3' length of 7/16" threaded rod. Worked really good too with 2 edges scraping away. Then I used a long strip of thin cardboard to slide the axleshaft back in to keep any dirt I may of missed off, then pulled the cardboard out when done. /forums/images/graemlins/thumb.gif
