reinstalling front carrier
Discussion in 'The Garage' started by cegusman, Apr 18, 2002.
  1. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    This weekend I will be installing a mini spool up front, what is required to reinstall the carrier correctly. Don't want to F*CK anything up.
  2. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    You need to pay close attention to how the shims come out and put them back the exact same way. You should check backlash when you are done just to be safe. Check out this link to the instruction manual at randys. It is quite helpfull.
    brent
    http://www.ring-pinion.com/yukon-instructions.pdf
