Reinstalling t-case - gasket question
Discussion in 'The Garage' started by Yukon Jack, Jan 6, 2003.
  1. Yukon Jack
    Yukon Jack 1/2 ton status
    Jul 25, 2002
    1,984
    Rose Hill, KS
    I'm gonna be reinstalling my drivetrain and a guy at the tranny shop told me I would want to use a thick gasket between my Rockwell T221 and the adapter between the SM465.
    When I separated the adapter from the Rockwell there was an extremely thin gasket no thicker than like 2 or 3 sheets of paper.
    I'm not even sure I can get gasket material that thin and pre-made gaskets for the Rockwell are difficult to come by.
    What would you recommend?
    Use a thick gasket sheet and make my own gasket?
    Use the thinnest gasket sheet I can find that is close to what was there?
    Use RTV and call it good?
    It does not even appear that there was a gasket on the tranny to adapter surface. Is there normally a gasket there?
  2. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    I would use thick gasket material (if it is a flush seal surface) and gorila snot it to hell to make sure it seals.
  3. Grim-Reaper
    7,385
    Atlanta
    Man I wish my local gear shop here still did their internet orders. I have as of yet to stump them. They are dirt cheap too. Sells me a gasket set (not including the output seals) for $6-8. Their site use to be www.southerngear.com
    I'd hit the local phone book and look up gears and see if you can find a shop that specializes in Manual transmissions. that's how I found this place near me.
